RV.Net Open Roads Forum: Hybrid Travel Trailers: Weight Distribution Hitch
Open Roads Forum  >  Hybrid Travel Trailers
 > Weight Distribution Hitch
drenjoey
Gray, Maine
Posted: 05/16/12 03:17am Link  |  Print  |  Notify Moderator
When we lost our 2004 Travelstar, I kept the WDH system for my next HTT.
We now have a 2011 Palomino Stampede S238 and the dry hitch weight is 411 lbs. My WDH is good for 600 lbs.
Are we in the limits or should we look for another WDH ?
Thanks
Dre
Mr Bojangles
Hamburg, PA. 19526
Posted: 05/16/12 04:18am Link  |  Print  |  Notify Moderator
Good to go...... but as always, performance is key.
SAFBVET.....
bikendan
Napa, Cal.
Posted: 05/16/12 01:34pm Link  |  Print  |  Notify Moderator
once loaded, it'll be close. i'm betting that, loaded, your tongue weight will be a little over 600lbs.
Dan- Firefighter, Shawn- Musician/Entrepreneur, Zoe- Faithful Golden Retriever, 2007 Chevrolet Avalanche LS, 2007 Rockwood Roo 23SS w/Equalizer and Prodigy, and 5 Mtn. bikes and 2 Road bikes
drenjoey
Gray, Maine
Posted: 05/16/12 04:45pm Link  |  Print  |  Notify Moderator
And what can happen if I'm over ?
wmoses
Houston, Texas, USA
Posted: 05/16/12 06:09pm Link  |  Print  |  Notify Moderator
At a GVWR of 6552# and assuming 12% to the hitch that would be 786# at the hitch, more if you are like many RVers who run overloaded.
Any rating will have some safety factor, but that is not what the margin of safety is for. Besides you would not know how much margin there is. It would be prudent to get a WDH rated for the heaviest load the hitch is likely to and then some.
If you are over it could result in bent spring bars our worse. Likely that would happen when you are in the middle of nowhere, and you would kick yourself for nor getting the right one.
Regards,
Wayne
2010 Jayco Jayfeather EX-Port 17Z | Tekonsha Prodigy P3 brake controller
2010 GMC Sierra 1500 SLE 5.3L Vortec V8 6-speed with Power Pack Plus Package | Hypertech Max Energy tune
_
drenjoey
Gray, Maine
Posted: 05/17/12 03:17am Link  |  Print  |  Notify Moderator
There's quite a margin between what Wayne and Dan are saying.
Dan is saying a little over 600lbs, and I would probably keep the WDH I have at the moment.
Wayne is saying 786lbs, and I would seriously think of getting a new WDH.
Dre
bikendan
Napa, Cal.
Posted: 05/17/12 09:27am Link  |  Print  |  Notify Moderator
i guess i should have said that the only way to really know is to weigh the tongue, when it's loaded.
i was just guessing that you'd be near the 600lbs., based on what i've read about other tongue weights.
