RV.Net Open Roads Forum: Buying a 2011 or 2012 ford F250 Gasser - advice?
Search only in Tow Vehicles
 > Buying a 2011 or 2012 ford F250 Gasser - advice?
Dave H M
IL
Posted: 05/16/12 03:54am Link  |  Print  |  Notify Moderator
The time has come to replace the teen ager F 250. I swung thru the local Ford truck dealer today to get a brochure and probably will make a much more serious stop tomorrow.
I am almost set on the 6.2 gasser for my needs. My fifth wheel weighed in at 10.5K dry with 1800 pin weight as i best recall - I will get the exact figures out of the file before I go in.
The sales person said that 2011's are really not out there.
Any basic thoughts or ideas? I really want to feel like i did not get hosed and yet get it over with and locally if possible
Mote
Westport, indiana
Posted: 05/16/12 04:00am Link  |  Print  |  Notify Moderator
I did a quick search on cars.com for 2011 gas powered F250's. The only ones left within a 250 mile radius of my southern indiana area are regular cab 2wd trucks. So I guess unless that's what you want the dealer is correct about the 2011's being gone.
wish you luck with you search
1996 Dodge Ram 2500 extended cab 2wd, Indy 500 edition Cummins diesel
2002 Jayco 325 BHS
gmcsmoke
Butler
Posted: 05/16/12 04:25am Link  |  Print  |  Notify Moderator
diesel
midnightsadie
ohio
Posted: 05/16/12 04:36am Link  |  Print  |  Notify Moderator
google the truck you want, some times you gotta travel to gey what you want.
therink
Rochester
Posted: 05/16/12 04:41am Link  |  Print  |  Notify Moderator
Make sure you get a 4:10 axle with a gasser if you plan on towing over 10k. I have heard good things about the 6.2.
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5'er
2012 Silverado 3500HD, SRW,LTZ,4x4, Z71, Crew, 6.0 Gasser, 4:10 Gears, Standard bed
"These days, I have problems in areas that I used to not have areas", so life is good.
M GO BLUE
Southgate, MI
Posted: 05/16/12 05:30am Link  |  Print  |  Notify Moderator
DIESEL
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fifth wheel
Onan 5500W Marquis Gold gas generator (HGJAB - 1038D)
MICHIGAN RALLY - July 19-21, 2013 Click here
therink
Rochester
Posted: 05/16/12 05:51am Link  |  Print  |  Notify Moderator
I'm pretty sure the OP doesn't want a diesel, just advice on gasser. Diesels aren't for everyone. Just saying.
agesilaus
North Florida
Posted: 05/16/12 06:19am Link  |  Print  |  Notify Moderator
Spend the extra $400 and get a 350.
Glendale Titanium 29E34TS fifth wheel
PullRite OE Series Super5th 18K
Superbumper
therink
Rochester
Posted: 05/16/12 06:23am Link  |  Print  |  Notify Moderator
I agree.
alexleblanc
Scoudouc N.B
Posted: 05/16/12 06:43am Link  |  Print  |  Notify Moderator
my suggestion as well. The 6.2 is a pretty good gasser, similar tot he V10.
TV - 2011 F150 FX4 EB | Max Tow Pkg | LT285/55R20E1 Tires | Airlift Bags
TT - 2011 Dutchmen 295BHGS Bunkhouse
Tow equipment - Reese Trunnion style 1200/12000 bars w/Dual Cam HP Sway control
Alex ('84)
DW ('81)
DD1 ('09)
DD2 ('11)
