RV.Net Open Roads Forum: Buying a 2011 or 2012 ford F250 Gasser - advice?
Search only in Tow Vehicles
 > Buying a 2011 or 2012 ford F250 Gasser - advice?
fla-gypsy
North Florida
Posted: 05/16/12 06:58am Link  |  Print  |  Notify Moderator
The 6.2L is getting good reviews. It is not as stout as the 6.8L V-10 but coupled with the 6 sp auto it gives similar performance. Towing way over 10k you may want to think about the rear gear hard and stepping up to a F-350. The 4.10 is no longer offered but a 4.30 is. The cost difference between the 250 and 350 is actually closer to $1200 but worth it for a 5th wheel that heavy.
ib516
Up here!
Posted: 05/16/12 07:00am Link  |  Print  |  Notify Moderator
F350 SRW, 4.30s. You would be disappointed with the 3.73s performance IMO.
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
APT
SE Michigan
Posted: 05/16/12 07:31am Link  |  Print  |  Notify Moderator
ib516 wrote:
F350 SRW, 4.30s
QFT
2012 VW Passat TDI
bmanning
Phoenix, AZ
Posted: 05/16/12 09:40am Link  |  Print  |  Notify Moderator
M GO BLUE wrote:
DIESEL
gmcsmoke wrote:
diesel
One size doesn't fit all, fellas...
I love diesel engines too but not everyone wants one
BManning
baking in Phoenix
2008 Ford Super Duty F250 XLT, 4x4, crew cab, 6.75' bed
5.4L V8 300hp/365ft-lb, 5sp Torqshift, 4.30 AAM gears
9400lb GVW 11200lb tow
2007 Volvo XC90 AWD V8
4.4L 311hp/325ft-lb, 6sp Aisin, loaded
6100lb GVW 5000lb tow
gmcsmoke
Butler
Posted: 05/16/12 10:02am Link  |  Print  |  Notify Moderator
Well if you're not ordering and trying to locate a v10 with a specific gear ratio you'll probably end up getting a better deal with a diesel; a much more common engine package.
jerem0621
Sequatchie, TN
Posted: 05/16/12 10:17am Link  |  Print  |  Notify Moderator
Geeze not everyone wants a diesel folks. 10k is not that heavy for a gasser.
TT: 1995 Layton 2910
Tow Vehicle: 1999 F-350, v10, 2wd, Crew Cab, Dually
Hitch: Draw-Tite Trunnion WD Hitch
Sway Control: Valley dual friction sway control
Brake Control: Tekonsha Voyager
"It's Kind of Fun To Do The Impossible"
~Walt Disney~
Kennedycamper
Algoa, Texas
Posted: 05/16/12 10:21am Link  |  Print  |  Notify Moderator
I like my diesel, but wouldn't want one newer than a 2007. They ruined the MPG advantage in 2007.5, and the OP doesn't need the power.
goducks10
Keizer OR
Posted: 05/16/12 10:31am Link  |  Print  |  Notify Moderator
FWIW Fords offering discounts of $4350 on superduty diesels. JMO but I would get the 4.30 gears with the gasser. 10,500 is a pretty good load.
fla-gypsy
North Florida
Posted: 05/16/12 12:52pm Link  |  Print  |  Notify Moderator
It may be more common but no way you will get one cheaper as the diesel is an $8k option to begin with and the 6.2 is the standard motor. The V-10 is no longer available in the pick up. Luckily I snagged one the last couple of years they made it for the pick up for a measly $600 bucks extra. The F-350SRW 6.2L with the 4.30 will do the job. BTW, the OP said it was 10.5k dry weight so we are talking in excess of 12k loaded here and approaching DRW territory.
gmcsmoke
Butler
Posted: 05/16/12 02:10pm Link  |  Print  |  Notify Moderator
Didn't say it would be cheaper but a better deal. What I mean is you'll end up compromising on features to get the powertrain you want. When all in all you'll only end up getting 8-10MPG towing. pay a few $ more have a diesel and give yourself more options.
