RV.Net Open Roads Forum: Class A Motorhomes: Roof Top A/C
 > Roof Top A/C
ronphil
New Bern
Posted: 05/16/12 09:45am Link  |  Print  |  Notify Moderator
Is it ever necessary to have "service" on roof top a/c. (i.e., inject more freon into unit)?
dougrainer
Carrolton, Texas
Posted: 05/16/12 09:53am Link  |  Print  |  Notify Moderator
They are SEALED(soldered) systems and have no ports for adding Freon. They have no ports or areas for Freon to leak out unless they have a cracked line. The maintenance is to keep the Evap and Condensor coils clean and the Air filter clean. Doug
Mr.Mark
California/Tennessee
Posted: 05/16/12 09:54am Link  |  Print  |  Notify Moderator
I'm sure the experts will pop in but the air units don't need freon unless they are leaking. We did have our front roof unit replaced under warranty as it bit the dust. The other two units work great and are very cold in 5 yrs of ownership.
You should check the roof units once a year to clean the 'fins' and to check for critter infestation.
Good luck,
MM.
Mr.Mark
2008 Monaco Dynasty, 42.2 ft., 4 slides, 425 hp clean-air Cummins diesel
2013 Honda CR-V EXL, AWD, w/Nav, SMI Air Force One vacuum-assisted braking
Clay L
Sioux Falls, South Dakota
Posted: 05/16/12 10:46am Link  |  Print  |  Notify Moderator
Other than keeping the coils and filters clean there isn't much you can do to them.
There are two sets of coils. One is on the back of the AC and the other is behind a sheet metal plenum. This is the cooling (evaporator coil) and inside air is circulated through it. Dust and pet hair can clog it and reduce efficiency and if bad enough can cause freeze up after running a few minutes.
Clay (WA5NMR), Lee (Wife), Katie (cat).
Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
Matt_Colie
Southeast Michigan
Posted: 05/16/12 12:36pm Link  |  Print  |  Notify Moderator
As a guy that has had to deal with a few of these, I can tell you that they should never need the refrigerant charge touched but at least semi-annual cover-off inspection is a good idea.
Be very VERY careful with the cover, they get extremely brittle after 10+years.
Some of the older Colemans had a place to oil the fan bearing, you won't even know unless you take the cover off. If you do oil the those bearing, the unit may well last as long as the rest of the RV.
Matt
Matt & Mary Colie
A sailor, his bride and their black dog going to see some dry places that have Geocaches in a coach made the year we married.
ArcticDodge
Sammamish, WA
Posted: 05/16/12 10:08am Link  |  Print  |  Notify Moderator
I have a good friend who's business is repairing commercial refer units on trucks & trailers. He helped me with a Coleman unit that went bad many years ago and this is what I learned... the units are "sealed" and do not have service ports installed. There are clamp on devices that pierce the tubing to allow for testing and charging. I was told they are really only a temporary solution. Turned out the compressor was bad most likely from never getting used.
2009 Komfort 256TS
2001 Dodge Ram 3500 QC 4x4 Cummins DRW
2005 Dodge Durango Limited AWD HEMI
2001 Sebring Convertible
1995 Miata M-Edition
2005 DRZ400
1 Wife 2 Boys UW & Bellevue College
1 Trixie (Bichon Frise)
Only 23 years to retirement!!!!
ArchHoagland
Clovis, CA, USA
Posted: 05/16/12 02:57pm Link  |  Print  |  Notify Moderator
I had to oil the squirrel cage shaft on both of mine about a year ago. The fan would not start unless you gave it a spin.
Mine did not have an oiling point, I just applied oil at the bearing edges and that cured the problem.
I exercise mine about once a month to keep everything moving.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
Nothing is either good or bad, but thinking makes it so.
 > Roof Top A/C
