RV.Net Open Roads Forum: Fifth-Wheels: laminate flooring
 > laminate flooring
pressure_welder
brandon
Posted: 05/16/12 09:46am Link  |  Print  |  Notify Moderator
Hey fellas/ladies, while cleaning the camper last night my wife and i noticed that our new laminate flooring that we had installed is starting to wrinkle or bunch up? hard to describe. We had a dealer install new flooring as during the winter the old******from the factory cracked and created a nice big tear. I just phoned the dealer and explained what was going on and they said they dont glue this type of flooring down is this correct? Nonetheless its getting sent back to be repaired.
2012 Duramax Denali Dually
2003 Triple E topaz 29' luxury touring edition.
1850 crestliner sportfish w/ 150 optimax
ScottG
Bothell Wa.
Posted: 05/16/12 09:50am Link  |  Print  |  Notify Moderator
That can happen if they force the "boards" together too tightly or they don't allow 1/4" expansion gap all the way around the perimeter.
Scott, Grace and Wesly
H0NDA eu2000i
the bear II
Torrance CA.
Posted: 05/16/12 09:54am Link  |  Print  |  Notify Moderator
Most laminate flooring floats on the subflooring. No nails and no glue, everything snaps together and just lays there.
The sub flooring needs to be stable or solid. If there is some give in the sub floor the laminate can bunch up due to movement.
1995brave
San Antonio, TX
Posted: 05/16/12 10:04am Link  |  Print  |  Notify Moderator
Probably installed while too cold. Most must be installed at a certian temp range.
thomasmnile
Deltona, Fl.
Posted: 05/16/12 02:59pm Link  |  Print  |  Notify Moderator
Wonder if a polyethylene vapor barrier was put down before plank installation? Laminate flooring is exquisitely sensitive to moisture, and an RV, especially when not in use,is hard to control humidity levels without AC or dehumidification. Then again, seems like placement of polyethlyene barrier over a wood product substrate in an RV might cause issues for the substrate......
I've read enough problems with laminate flooring in RV's I guess I'm glad I've got the old stapled down carpeting. YMMV.
John Bridge
Houston
Posted: 05/16/12 03:05pm Link  |  Print  |  Notify Moderator
I'm voting for the lack of expansion room around the perimeter.
I don't think moisture would be the problem.
Semi-"retarred" in 2006. :-) 2008 Newmar Cypress 5th wheel, 2008 Dodge diesel dually to pull it with.
pressure_welder
brandon
Posted: 05/16/12 03:14pm Link  |  Print  |  Notify Moderator
hmm maybe i shouldve specified a little better guys i apologize. Its a simulated wood design, much thicker than the factory garbage. But its like a sheet of lenolium.
Ohiojude
Greensburg PA
Posted: 05/16/12 04:53pm Link  |  Print  |  Notify Moderator
OP we were told the same thing about not using glue. I questioned that the flooring seemed "raised" on our new Raven and was told they don't glue them. The mfg of the flooring suggested not to glue. So far so good. I vac and wash with no issues.
05 Chevy 3500 LT/Crewcab/duramax diesel/allison, 2012 Raven loaded and always ready
azbohunter
arizona
Posted: 05/16/12 05:51pm Link  |  Print  |  Notify Moderator
It floats and is usually glued only at edges.
2006 Dodge Quad Cab Cummins 5.9 Automatic 4x4
2002 28RKD Lakota fifth wheel
Pullrite Hitch
2006 Polaris Ranger
16'Lund w/50HP Merc tiller
A great wife who loves to travel and fish
I love to archery hunt/she joins me and cooks!
buc1980
houston tx
Posted: 05/16/12 08:17pm Link  |  Print  |  Notify Moderator
Ohiojude,for how long you install the laminate floor?
2011 Ford F350 DRW,2005 Kountry Star 35ft,Breaksmart controller(not install I use Ford controler ),Equa-Flex.6 points LIPPERD Level-up.
 > laminate flooring
