pasusan
PA
This past mod season (winter) I replaced the water pump with a Shurflo Revolution pump with a rubber mounting base. I added an accumulator tank and replaced the plumbing lines around the pump and accumulator with flexible hoses. Everything tested out well at home and it was definitely more quiet than the old pump.
We carry about 1/3 tank of fresh water when we're on the road. On the first leg of the first trip of the year we were pulled off in a rest area for lunch. Turned on the pump to wash our hands and whatnot, then ate lunch. After lunch we were going to clean up the dishes and there wasn't any water. One of the low point drains had come slightly open and been leaking. The pump was running the whole time without us hearing it and all the water was pumped out onto the ground.
Moral of the story is - rejoice in your loud pump - at least you know when it's running!
Trip Pics
"Don't let the sound of your own wheels drive you crazy." JB & GF
Susan & Ben ~
84 Bronco & 90 Award Classic 23 joined with a Hensley Cub
mowermech
Billings, MT
Good point!
When the main water line in my 1977 Pace Arrow broke while I was sitting outside, if the pump hadn't been loud I would have never noticed it.
It would have pumped the entire contents of the tank into the storage area under the bed before any dripped to the outside!
There ARE times when a little noise is a good thing!
CM1, USN (RET)
Toad: 2006 Jeep Rubicon LJ
Dick_B
Palos Heights, IL USA
This is why we rarely hook up to the campground water system but prefer to fill the FW tank. Ours isn't as quiet as yours but is tolerable.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
Bucky Badger
Madison, WI
Yeah, the loud pump doesn't bother me at all
Fred & Jodie, dogs, Zoey & Mika
RIP Bella
2010 F150 5.4, 3.55, 4x4, Equli-z-er Hitch
2007 Forest River Salem 27RB LE
and
2009 Nomad 3980
AJR
Close to Madison Wisconsin
I like to know if something is leaking. The pump will tell you that.
2002 Damon Challenger 348
W22 8.1 Vortec
2010 Escape toad
Emptypockets
North Central KS
AJR wrote: I like to know if something is leaking. The pump will tell you that.
X2
Lantley
Ellicott City, Maryland
I have never quieted my pump for that exact reason. Not so much for leaks, but if we are using the pump than our water supply is limited. I want to know (hear) If someone is using water.
I consider the pump noise a in use alarm.
edited 05/16/12 07:57pm by Lantley *
07'Duramax dually,12'Open Range 399BHS
Hawkshead TPMS,Hensley BD3,Killerbee exhaust brake
Blue Ox Bedsaver,air bags w/compressor
Arvika pin box bike rack,Bak Flip tonneau cover
5500 Onan LP,EMS-HW-50
14'Porta Bote w/8.0 Nissan
Vu Cube 2000,Splendide 2000S
korbe
Northern California
Bucky Badger wrote: Yeah, the loud pump doesn't bother me at all
10-4, plus I never hear the pump while in the shower.
2004 F250 SD PSD
2004 Crossroads Cruiser CF25RS
coolbreeze01
Redding, Ca
Retro to the hand pump for real water awareness
2008 Dodge 3500 With a Really Strong Tractor Motor...........
LB, SRW, 4X4, 6-Speed Auto, 3.73, Prodigy P3, Blue Ox Sway Pro........
2007 Komfort 212 on 225 75R 15E Maxxis 8008 Tires.........
Lantley
coolbreeze01 wrote: Retro to the hand pump for real water awareness
That's funny.
