westend wrote: Does the Proflex or Geocel hold paint?
The tubes I have say it is paintable. We will find out soon as I have a little project I used some from (rather than it going to waste) a leftover tube, and will be doing a camo paint job on.
I found on more than one occasion that once opened, a tube of proflex doesn't have a long shelf life (even with the top plugged)
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5'er
2012 Silverado 3500HD, SRW,LTZ,4x4, Z71, Crew, 6.0 Gasser, 4:10 Gears, Standard bed
"These days, I have problems in areas that I used to not have areas", so life is good.
That is why I started looking for things to use it on very quickly. I opened it on 4/28. So far I caulked some stuff on the trailer (4/28), caulked some stuff on the bird house my son made (4/29, 5/6, and 5/7), and caulked stuff on my homemade parellel kit for the Hondas I am reworking to reduce space and weight (5/11, 5/12, 5/13, and 5/14). I still have half the tube left. It is clear. Anybody in my area need to put some clear ProFlex RV on something?
I have used Dicor and ProFlex and both are excellent products but with my limited DIY skills, found them very difficult to work with. I just spent several weeks researching sealants just for fun. Even talked to a couple of RV manufactureres about sealants. The one thing that remained consistent was the recommendation of a urethane/polyurethane product not a silicone.
In my search I found some products made by Tremco. The sealants are called Trempro. I decided to try the Trempro 626. I selected it for several reasons including its use for continuous immersion in water (I live in the Pacific Northwet)and because it comes in several colors. I am in the process of resealing my entire rig...its about half done.
The upside is the sealant is very easy to work, color matches our rig, and it is relatively inexpensive for a quality sealant ($7.95) at Fastenal Stores. The downside is it takes forever to dry and is not readily available...could only find at Fastenal stores and they had to order it. It is a textured sealant meaning when dry it looks similar to brick mortor rather than a smooth sheen like silicone. Doesn't bother me or look bad on the rig.
Just throwing it out as an option!
Best Wishes!
2011 Heartland Big Country 3450TS
2007.5 Chev LMM Duramax/Allison
2010 FLHTC Electra Glide Classic Red Hot Sunglo
Heartland Owners Club - Washington Chapter Leaders
Has anyone painted over either Geocel or Proflex caulk? I have four tubes of Geocel in hand and have just spent two days removing previously applied sealants on ALL the joints on my rig. I am about to prime and paint the whole trailer so I need to know how the caulk accepts paint. I can put it on post-paint but the right way would be to get it on first and then put on the finish paint.
