RV.Net Open Roads Forum: Should Tire Max Load = Trailer GVWR???
 > Should Tire Max Load = Trailer GVWR???
TOOBOLD
CALI
Posted: 05/16/12 08:37pm Link  |  Print  |  Notify Moderator
We have to shop for tires as one of our tires appears to have a hernia. We have a Jayco 31.5 BHDS 5er with GVWR 10,700. Currently, the tires are Goodyear Marathons ST225/75/15 D with each have a max load rating of 2540lbs. Well I did the math and that only equals 10,160.... so I'm about 540 lbs shy of the GVWR.
Is this because of the pin weigh distributed to the truck? School me please. Not sure if we should get he E rated tires, but then will the stock rims be able to hold the additional pressure? Help.
fla-gypsy
North Florida
Posted: 05/16/12 08:40pm Link  |  Print  |  Notify Moderator
You are correct in they subtracted the pin weight. The tire weight rating SHOULD be equal IMO but it is not the norm. I am fortunate that my TT tires and axles are rated for the full weight of the trailer.
JJBIRISH
Butler, PA, USA
Posted: 05/16/12 09:36pm Link  |  Print  |  Notify Moderator
My tires and wheels are rated for the full GVWR (10,000) and in my opinion are still somewhat undersized…
IMO the tire rating should equal the GVWR or the GAWR plus 10% whichever is greater… the tires are the most stressed part on the trailer…
Love my mass produced, entry level, built by Lazy American Workers, Hornet
Golden_HVAC
Fulltime, CA, USA
Posted: 05/16/12 09:14pm Link  |  Print  |  Notify Moderator
HI,
I agree that having the tires rated at the GVWR would be a great idea, and the axle weight is only going to be something between 8,000 and 9,000 when loaded fifth wheel is around 10,500 pounds GVWR.
But if you have a blowout, and put nearly 4,000 pounds of one side of the trailer onto one tire, you will surely damage the inner casing of the tire if you did not notice the blowout and kept driving a mile or more at freeway speeds. So having tires with a slightly higher rating is good insurance in my book.
Even if I did have a blowout, I am not really going to stop right away, especially if on a two lane highway, I will wait until a wide section of road that is somewhat straight, not a passing lane. So what if I destroy one bad tire and ruin that rim, I am not getting out on the road side of the trailer to change it on a blind curve, or at night. I can get a newer rim for $35 at a junkyard. Even new rims with tires mounted on them are fairly low cost here. ETrailer.com
So yes the factory did size the rims and tires correctly at around 2,500 pounds each for the expected maximum 5,000 pound axle load, that really should not be over 4,500 pounds per axle if you are not exceeding the GVWR, and might only be around 2,100 pounds on each tire in normal use without the trailer fully loaded.
Fred.
jassrnj
Bath, PA
Posted: 05/17/12 07:32am Link  |  Print  |  Notify Moderator
Putting on tires with a higher load rating is a great idea. Did you ever watch the tires on a TT as it is going down the road. There is a lot of flexing going on as the TT moves up and down. Tires take a beating on a TT.
coolbreeze01
Redding, Ca
Posted: 05/17/12 08:11am Link  |  Print  |  Notify Moderator
Went from C to load range E about 11,000 miles ago. So far, so good.
2008 Dodge 3500 With a Really Strong Tractor Motor...........
LB, SRW, 4X4, 6-Speed Auto, 3.73, Prodigy P3, Blue Ox Sway Pro........
2007 Komfort 212 on 225 75R 15E Maxxis 8008 Tires.........
jauguston
Bellingham, WA
Posted: 05/17/12 08:15am Link  |  Print  |  Notify Moderator
GVWR is just a number. What do the axles actually weight when you are loaded up for a normal outing? That is the number you should actually plan around.
Jim
2005 Coachman Sportscoach Elite 402 40'
350hp Cat C-7 w/MP-8
7500w Onan quiet diesel generator
6-Kyocera 130w solar panels SB3024i MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
jims1
NC
Posted: 05/17/12 08:31am Link  |  Print  |  Notify Moderator
My 5'er has a gvwr of 12900, on 5200lb axles.
I had Firestone Transforce 235-85-16 E installed on it.
Its a little overkill as the tires are rated for 3042lb X 4= 12000,
but I have plenty of reserve capacity in them.
I also got a deal on them. Right at $600 installed
'06 Ram with a Cummins
Tuned w/ EFI-Live
'09 36MAX1 Carrilite
Me, Alie, and Salie
JJBIRISH
Butler, PA, USA
Posted: 05/17/12 08:49am Link  |  Print  |  Notify Moderator
Jim
The GVWR is just a number, but it is the number used for proper sizing the trailers parts for safe operation…
When sizing tires, they should be sized for the maximum load that they may have to carry and not the load that sits on them today…
You can use the inflation/load tables for today’s load if you choose to but not for sizing and fitting the tires…
Total loads change in the RV’s from one trip to another and during trips, especially on long trips…
The tires should be sized for the maximum load limited only by the chassis maximum load capability…
With trailer tires it is prudent that the tire sizing should also include a reserve capacity of at least 10% that is not included in the tires sidewall rating from the mfg…
jauguston
Bellingham, WA
Posted: 05/17/12 08:58am Link  |  Print  |  Notify Moderator
My point although not very clear was the chances are good that in a lot of cases the actual axle loading when ready to travel will often be higher than the GVWR.
Jim
