RV.Net Open Roads Forum: No water coming through the Hot Water Line
 > No water coming through the Hot Water Line
MSW
San Antonio, TX
Posted: 05/17/12 08:40pm Link  |  Print  |  Notify Moderator
Thanks! It was sentiment in the tank. I flushed the Hot Water heater and everything worked like its suppose too.
Happy Trail's
jones4110
Champlin, MN
Posted: 05/23/12 06:53pm Link  |  Print  |  Notify Moderator
just for the record, on Fleetwoods your hot water will not work if your outside faucets are in the open position with the shower valve in the closed position. Don't ask why, just accept as a simple truth.[emoticon]
Joan and Bruce
05 Excursion 39L
powered by 350 KittyCATS on a Spartan
2010 Traverse LT toad (Blue Ox & Breakbuddy)
...and a "road dog" named Max and his gabby sister, Abby.
"May the wind be always at your back and your destination the one you chose"
donandmax
Delta Co.
Posted: 05/24/12 06:14am Link  |  Print  |  Notify Moderator
Outside faucets ? The only outside faucet we have is the shower (outside) faucet. Useless item as we have never used it in any rv we owned. Would be afraid too anyhow as they are made so cheaply.All they are good for is to leak..But then we dont own a Fleetwood.
If it aint broke fix it till it is
jones4110
Champlin, MN
Posted: 05/24/12 10:37am Link  |  Print  |  Notify Moderator
Yes the shower head has knobs where the shower extends and they must be in the closed position. This just my humble experience which I have shared with many others to solve their hot water issue. [emoticon]
That shower valve should have been opened if you winterized.
MSW
San Antonio, TX
Posted: 05/25/12 09:49pm Link  |  Print  |  Notify Moderator
I cleaned flushed the tank three times. I also used White Vinegar to break up the sentiment. The hot water worked when I tested it. Again I have no water running through the hot water line. What does a check vale look like?
© 2017 CWI, Inc. © 2017 Good Sam Enterprises, LLC. All Rights Reserved. | Terms of Use | PRIVACY POLICY | YOUR PRIVACY RIGHTS
