RV.Net Open Roads Forum: Hybrid Travel Trailers: Tub Support
Open Roads Forum  >  Hybrid Travel Trailers
 > Tub Support
TMGS11
SW OF ATLANTA
Posted: 05/17/12 12:29am Link  |  Print  |  Notify Moderator
While working on a tub drain issue I realized that the tub was only touching the the tub support platform in one place. I was able to lift the platform one half inch all around and the tub now is firmly touching the platform. I don't get that sinking feeling when stepping into the tub anymore either.
Question: Would it be wise or overkill to spray some of that expanding foam under the tub between the tub bottom legs and the platform it sits on? Any thoughts on this will be appreciated.
Thanks
03 2500 Ram 4x4
11 Trailmaster 321TBS
MudChucker
Niverville Manitoba
Posted: 05/17/12 04:35am Link  |  Print  |  Notify Moderator
I had a TT were the tub would buckle when I stepped in it... I glued some wood support around the drain area and filled a garbage bag with spray foam and shoved it under the tub the entire length of the tub was supported by the bag full of foam..
2005 PILGRIM 274RL 5SS
2007 GMC Sierra 2500HD SLT 6.0
Geozzz
South Jersey
Posted: 05/17/12 05:34am Link  |  Print  |  Notify Moderator
Expanding foam will add much stability to your tub base. When installing foam use several plastic bags and spray the foam inside the bags. that way if repairs must be made at a later date, the foam can be removed without being stuck to everything.
Kathy & George Zimm
Mickleton NJ
2006 Coachman Epic and 2011 Chevy Equinox toad
2 Shelties
llowllms
Crawford, Tn. USA
Posted: 05/17/12 09:04am Link  |  Print  |  Notify Moderator
I guess we were lucky with our ROO, never had a problem with the support.
 > Tub Support
