Minnesota*is*Home
Minnesota
This is our first full summer of camping with our 25' Coachman TT. Our issue needs some creative solutions. We tow with our Tahoe which has fold-in side mirrors. When hubby straps the extended side mirror onto the driver-side mirror, the whole mirror folds itself in at highway speed. What can I do to the truck's mirror to keep it from folding in??
beemerphile1
I'm 57, I'm not a
Glue them in the outward position, maybe? I'm just messing with you, I really don't know. Welcome to the forum.
Some of us use McKesh mirrors or Camping World has a wide selection of mirrors. It sounds like you may have to use a different mirror system.
http://www.safetowingstore.com/McKesh-Mirrors-p/70007.htm
- Soren Kierkegaard
lmsteck
Northern California
We took off the stock mirrors on our truck and replaced the whole system.
agesilaus
North Florida
I tried all sorts of strap on mirrors on our old Suburban and never was happy with any of them. It's probably a lot easier in the long run to just replace the mirrors with real tow mirrors.
Glendale Titanium 29E34TS fifth wheel
PullRite OE Series Super5th 18K
Superbumper
Sloop Smitten
San Marcos, CA
I had a similar problem with the mirrors on my Jamboree. Nothing seemed to work unitl I drilled a small hole in the arm of the mirror right next to the pivot hinge and inserted a screw that I could use to lock the position. Barely noticeable and solved the problem. Might try it before you dole out for new mirrors. You can remove the screw when not towing the trailer.
1992 Fleetwood Jamboree Rallye 24' M/H
Ford E350 Chassis, 7.5L Engine, E40D Transmission
My other motorhome is a 1978 Catalina 25 Sailboat
Cruising Califonia, Sailing the Pacific!
CincyGus
Cincinnati
I put these on my Silverado and love them. Kept the heated mirrors and power adjustment functions working and they are fantastic.
2011 Silverado Crewcab 4x4
2012 Passport 238ML
Hope your travels are safe and the friendships made camping are lasting.
