RV.Net Open Roads Forum: Travel Trailers: Equalizer 4 point
 > Equalizer 4 point
jassms98
inland empire
Posted: 05/17/12 02:39pm Link  |  Quote  |  Print  |  Notify Moderator
Trying not to over complicate setup on my WDH But views on this forum safety is a must.
Truck measurement 37in Front rear 36 1/4. With trailer hooked up bars attached.
TT front 22in rear 20 3/4 inchs. WDH bars are parallel with frame. That being said bars are not makeing full contact with L brackets Hitting on edges.
Smeared white grease on L brackets to see contact point. driver side towards the back of the bracket. Passenger side towards the front part of bracket. Is this normal or more adj needed. Have 5 washers in head.
Should i adj head or l brackets on frame. Sorry no picks. Thxs all just want it right. joe
2011 F150 4x4 6.2 Platinum
2012 ViewFinder 28BHSS
Equal i zer WDH
Ron Gratz
full time RVer
Posted: 05/17/12 03:53pm Link  |  Quote  |  Print  |  Notify Moderator
jassms98 wrote:
---WDH bars are parallel with frame. That being said bars are not makeing full contact with L brackets Hitting on edges.---
Are the L-brackets perpendicular to the frame?
Ron
aftermath
Washington State
Posted: 05/17/12 03:55pm Link  |  Quote  |  Print  |  Notify Moderator
It sounds to me like your trailer is not level. It is very important to have your double axle trailer level as it goes down the road or slightly low in the front.
When your L brackets are mounted perpendicular to the frame you should have good contact with the bars.
Try lowering the ball a bit and check for level on the trailer before you do anything else.
2008 Toyota Tundra, Double Cab, 5.7L V8
2006 Airstream 25 FB SE
Equalizer Hitch
Prodigy Controler
jassms98
inland empire
Posted: 05/17/12 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
That was it. Had second thought about asking but glad i did. the bracket were off slightly. Will tow friday about 100 miles. Thxs joe
goducks10
Keizer OR
Posted: 05/17/12 05:07pm Link  |  Quote  |  Print  |  Notify Moderator
Your TT is 1-1/4" high in the front. Thats a no no. You need to slide the hitch head down 2 holes on the shank. That way you'll be 3/4" low in the front but thats better than being high in the front.
jassms98
inland empire
Posted: 05/17/12 08:09pm Link  |  Quote  |  Print  |  Notify Moderator
Being high in the front is bad why. This is all new to us. Joe
Padlin
W. Ma.
Posted: 05/18/12 12:02am Link  |  Quote  |  Print  |  Notify Moderator
You are supposed to adjust the hitch height on the "L" shank to a height that makes the trailer front and back equal according to the Equalizer manual, your the other way around. You need to drop the hitch a hole or maybe 2 down the shank. On mine it doesn't work out to be exactly equal so you should err to the hole that makes the front end of the trailer a bit low. You can use the shank either pointing up or down, depending on your needs, you can also get them with different lenghts if needed. There is a calculator for the correct shank at the Equalizer site but for some reason I can't get a link to it to post.
* This post was edited 05/18/12 12:17am by Padlin *
Happy Motoring
Bob & Deb
W Ma.
12 F150 HD SCAB EcoBoost LB 4x4
06 Starcraft 18SB
aftermath
Washington State
Posted: 05/18/12 12:37am Link  |  Quote  |  Print  |  Notify Moderator
If it is high you are transferring weight to the rear tires. Your rear tires will wear out faster and could even be overloaded. This is not a good thing.
When trying to level the trailer it might be next to impossible to get it exactly level. People say it is OK to be slightly lower in the front as this moves more weight forward and toward the ball. This increases stability when towing.
So, shoot for level but if you have to be off a tad, get the front a little lower than the rear. Hope that makes sense.
rode2nowhere
southern indiana
Posted: 05/24/12 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
I am getting to redo my setup after getting a different tow vehicle,noticed the washers and the button bolt or whatever it is is loose, is this normal? It is not mounted on the truck but I thought it was a bolt?
8iron
Canada
Posted: 05/24/12 08:19pm Link  |  Quote  |  Print  |  Notify Moderator
No, it's just a pin that goes into the hole in the shank. If it is loose, there is a set screw under that washer pin that needs to be tightened to keep everything snug. Once it's snug tighten the big bolts to spec torque.
2011 F250 Lariat FX4
2011 Sunset Trail Reserve 29ss
 > Equalizer 4 point
