RV.Net Open Roads Forum: Travel Trailers: Equalizer 4 point
 > Equalizer 4 point
opnspaces
San Diego Ca
Posted: 05/24/12 08:22pm Link  |  Quote  |  Print  |  Notify Moderator
rode2nowhere wrote:
I am getting to redo my setup after getting a different tow vehicle,noticed the washers and the button bolt or whatever it is is loose, is this normal? It is not mounted on the truck but I thought it was a bolt?
Not normal. When you move it to the new truck make sure all is tight. On mine (and I think it's in the manual) I left the big side bolts loose and hitched the trailer including the WD bars. Raised the tongue jack so all the weight was on the hitch. This put all the pressure on the washers. Then tightened the 5/8 inch bolt on the bottom of the head and tightened the large side bolts.
Eventually I'll probably have to do this again, but so far it's been tight for a few years.
1996 Suburban 4x4. 350, 4.10 3/4 ton
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
rode2nowhere
southern indiana
Posted: 05/25/12 04:50am Link  |  Quote  |  Print  |  Notify Moderator
thanx for info
 > Equalizer 4 point
