nayther
Burbank, CA
I always slide my truck under the hitch with the handle in, that way I can see the handle pop out/in. After that I check that the jaws are wrapped around the pin. Reese 16k slider bought with the trailer, second truck.
DIRT BIKES RULE
'12 Duramax CC short bed
'06 3005 Rage'n Falcon
Spitse
Oklahoma
Check to make sure the kingpin goes below the Jaws. It may be the jaws are not closing fully because the Kingpin is larger at the bottom than the middle. My reese will allow the relese pin to lock like this and still allow the kingpin to slide out. I usually close the jaws, drop the trailer all the way, then put truck in "N" to let it sellte, then check everything a second time.
jasonlisan
Colorado
I have a 22k Reese hitch, this is how I hook up. I always make sure the trailer is a bit lower than the fifth wheel so when I back up the trailer actually lifts a bit onto the fifth wheel and I can see the handle move out then in. I get out of the truck to make sure the jaws are wrapped around the king pin. Sometimes I do a pull test to make sure it's locked but not always & so far knock on wood I haven't had any issues.
mr. old style
wisconsin
jackxclan wrote: Keep all the hitch parts well lube'd.
Is iut very old? could have worn parts?
I'm not sure what the life expectancy is but its 2 years old maybe 6,000 miles on it. I would think they last longer than that.
mr. old style
wisconsin
jasonlisan wrote: I have a 22k Reese hitch, this is how I hook up. I always make sure the trailer is a bit lower than the fifth wheel so when I back up the trailer actually lifts a bit onto the fifth wheel and I can see the handle move out then in. I get out of the truck to make sure the jaws are wrapped around the king pin. Sometimes I do a pull test to make sure it's locked but not always & so far knock on wood I haven't had any issues.
I actually just read that in the owners manual about having trailer lower and "forcing" it (plate) under. I've never done that but will from now on. I also wasnt aware you could have the jaws closed - handle in, when you hoked it up. I will also look into that.
Thanks
mr. old style
wisconsin
asuperheat wrote: I'm thinking I would get a new hitch. Either there is a serious issue with yours or you are not locking in the hitch all the way. If the jaws are closed around the kingpin upon conecting and the safety pin is in so it cant release it must be broke. I just don't see how a hitch could just release. Are you not putting the safety pin in the hitch before you move it? If not I guess it could release. Are you using a teflon lube plate that is to thick maybe so the jaws on the hitch are not engaging all the way then closing the hitch lever and not putting in the safety pin? Moving the rv then BOOM?
I dont believe I have a "sfety pin" there is a little flapper that drops down into a groove on the handle so you can put a padlock on it. Is that what youre refering to? If so - no that was not down and locked in place. I am using a teflon plate, and will check that out. I'm really starting to lean towards operator error, as I probably didn't check things out as well just pulling out of the shed like I would have if going on the road.
Thanks
old guy
Oregon (pronounced Or e gun)
you are doing your pull test with the landing gear too high. I would try it with them in a lower position
Badhabt
Puyallup, WA
seattlefirervr wrote: Hijacker hitch. Far better locking system than Reese or any other!
I too have the Hijacker...no uncertainty when you hook up.
06 F350 4X4 Crew Cab Dually Tow Boss
07 Raptor 3612DS
92 Banshee - sons now
06 YZF450 50th Anniv Edition - sons too
06 Raptor 700R 50th Anniv Edition - mine
06 Wolverine 450 - wifes
07 Wolverine 450 SE - my other toy
4*phun*2
Canada
I think you are raising your TH to high when hooking up. I always force my TV under the TH when hooking up. Then get out and check the connecting.
Glenn & Karen
'08 Chevy LT 3500 HD 4x4 CC LB DRW (nice hips)
'06 F350 4X4 Lariat CC LB DRW (nice hips) retired
'09 Victory Lane 38SRV Toy Hauler
'02 HD Road King FLHRCI KRUZN
'04 F150 XLT Super Crew
Our Toys
hallock5
I too always have the rig about 1/4" lower than the TV, where it has to do some minimal lifting (at idle speed). I also never move it until my safety caribiner is inserted and has the handle locked in place.
2008 Jayco Eagle Superlite 28.5RLS
2002 Ford 4x4 SuperCab 7.3 (Jr International) Diesel
Sad to say, time to sell to a good home.
