FW
Livingston, TX. USA
MrWizard; If your coach is in the 1998-2002 year bracket with
that 5.9 isb, it could be a 53 block. That block has a weak side.
Google "53 block".
Mine is (5.9isb 275hp) and at 54k miles it zippered just last year.
Frank & Cyndi
Full time since 1/3/03
2000 Monaco Diplomat
2002 Chevy Tracker 4x4
ryanallie1
Magalia, Calif
Hi All.
Hey Mr Wizard. We sure hope its nothing to bad. That really has to be a real bummer. Breaaking down is bad enough all by itslef. But when you think you may have lost an engine, that really is the biggest bummer of all times.
We hope for the best for you and your Motorhome. We'll keep our fingers crossed for yoou and pray it isn't to bad.
We will be following your posts for more information. Good Luck. Happy Travels. Dan & Jill
1998-33.5 Rexhall, Rexair SL. 460 EFI. F-53. 7.3 MPG. TST TPMS. HWH Levelers. 5.5G Gen. Convection/Microwave Water Purifier/Water Softner. 2 A/C's. Alarm Systems. Honda EU2000i's W/Kit. Steer-Safe. CR-V W/SMI System. FMCA #F414397 Nam-Vet, 66-67-68&70-71
CT_WANDERER
E. Lyme, CT
Cracked injector will cause white smoke, but you should be able to smell the fuel.
Edit after rereading your post.
Fotget what I said about white smoke as you said it was comming from your coolant tank.
MrWizard
Traveling
@ executive
I didnt know where to go i was dependent upon the ers rep the rep was using a computer and phone to find out where to take me i think the ers rep is in florida
I asked the tow driver what he knew about them
He said they mainly did collision repair and interiors but that yhey had good diesel mechanics and only 3 places would in the area would work on RVs
Here one in flagstaff and one in pheonix
When your on the road your between the rock and the hard spot
last
edited 05/19/12 01:48pm by MrWizard *
View edit history
Connected thru Verizon with HotSopt WiFi using a Samsung Galaxy Nexus
I BOUGHTthis phone
MrWizard
Traveling
Coach is a 1995 engine is oem with 138347 miles
hottubkid
SCHAUMBURG,IL
Maybe try some super glue to get you to the repair place. This is pending how bad the tank is broken
CA Traveler wrote: I'd be tempted to patch the tank, fill with water just to determine the engine status. I'm not suggesting highway driving.
hottubkid60193@yahoo.com
2004 SOUTHWIND 36E Tow 2003 CRV
Living On
Where Ever
hottubkid wrote: Maybe try some super glue to get you to the repair place. This is pending how bad the tank is broken
Won't work. Wasting your time unless you take the tank off and clean and clamp once the SG has been placed. Water under pressure will overcome SG.
JC2
Mo
Depending on where the crack in the tank is, strip of eternabond tape maybe?
2004 Newmar DSDP 4015,370hp Cummins ISL,Spartan MM Chassis,2008 Saturn Vue,FMCA #402879,NKK 19776
lanerd
Newport, OR
So very sorry for your troubles... but I gotta ask. Weren't you paying attention to your temp gauge? Overheating an engine is just like running outta fuel....there's just no excuse for it.
Again, very sorry this happened to you. Hope all turns out well for you.
Ron
Ron & Sandie
'08 Safari Simba SBD35 CAT C7
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Safari Intl, CAT
RETIRED!! How sweet it is....
hypoxia
Arizona
After reading about your tank bursting, I decided to patch mine which I noticed was seeping through a crack. I wrapped 4" eternabond webseal around it & took a couple of sewer hose clamps & reinforced the eternabond with the hose clamps. Hopefully that will get me back to the Valley of the Sun where Chandler Freightliner will be happy to lighten my wallet.
Jim
2003 Fleetwood Revolution 40C
