CT_WANDERER
E. Lyme, CT
boy sure look like a lot of carbon on one piston compaired to the other. Looks like some of the cylinders were not running as good as the others.
2bzy2c
California
Just curious. How many miles do you have on that engine?
My advice is worth exactly what you paid for it.
MrWizard
Traveling
I think Jim was joking about the pistons
Not carbon thats where the top of the piston is crumbiling
138437 miles on the engine sround 7000 hrs
edited 05/27/12 10:03am by MrWizard *
Connected thru Verizon with HotSopt WiFi using a Samsung Galaxy Nexus
I BOUGHTthis phone
Jim@HiTek
Gresham, OR, USA
MrWizard wrote: I think Jim wad joking about the pistons
You are correct sir!
Jim@HiTek
Have shop, will travel!
Visit my travel & RV repair blog site. Subscribe for emailed updates.
Fleetwood Bounder, '94
Cummins Diesel, 190HP, 36.5' with 50HP LP boost.
Black Rock Lava Park, Nevada
slickest1
canada
Sorry, I thought it was an 8.3 cummins, when I made the comment about new liners. good luck with your new engine.
2000 H.R. Imperial 38wds rr8r roadmaster, isc 350 cummins
2007 Chevy Trailblazer, Blue ox towbar
Ready Brake with breakaway.
chevylover1965
Southern CA
I would be interested in hearing from Mr. Wolfe on this issue if he is available.
06 Tiffin Phaeton 40 QDH
Freightliner, CAT
08 Honda CRV EXL/NAV
Roadmaster Falcon All Terrain tow bar/US Gear
FBINA 144
jwmII
out west
slickest1 wrote: Man that piston is bad! I am surprised they are not replacing the liners.The head looks good though. I hope your up and going soon.
I thought the Cummins B5.9 was not a lined engine. They probably were able to clean up the cylinders by honing,thus the.012 oversize pistons mentioned earlier.
jwmII
Haulinas
On the road
Okay, 14 pages and no answer as to what caused the overheating? I'm with whoever suggested changing the inj's. I'd be checking that head for warp.
racedaymechanic
Race City USA
Haulinas wrote: Okay, 14 pages and no answer as to what caused the overheating? I'm with whoever suggested changing the inj's. I'd be checking that head for warp.
If you read the whole thread he says several times his plastic overflow tank cracked and he lost all his coolant
2009 Sabre Palomino "Sissy"
1998 Chevrolet K3500 6.5 Diesel "Brutus"
ptwiringsolutions.com
MotorPro
racedaymechanic wrote: Haulinas wrote: Okay, 14 pages and no answer as to what caused the overheating? I'm with whoever suggested changing the inj's. I'd be checking that head for warp.
If you read the whole thread he says several times his plastic overflow tank cracked and he lost all his coolant If you crack an overflow the only water you will loss is the overflow. That would not cause overheating. Something had to cause all the water to be pushed into the overflow tank(extreme high temp or high pressure from blown head gasket) more then likly the tank broke from the high pressure.
