RV.Net Open Roads Forum: right turn signal not working on hooked up toad
 > right turn signal not working on hooked up toad
trnfla
Tampa
Posted: 05/19/12 05:38pm Link  |  Print  |  Notify Moderator
Only make left turns... Sorry could not help myself....
Please say a Prayer for my 5 year old Granddaughter (Discovered she had Leukemia at 9 months), she has been in remission and tests keep coming back clean.
Now 2004 Winnie Minnie 31C
Had 2007 Zeppelin 190 Hybrid,
1999 30' Dutchman Classic FW
NiceCamps.com
cac43
mo
Posted: 05/19/12 08:45pm Link  |  Print  |  Notify Moderator
thanks for all of the good advice- i'm dumb where is and what does a diode look like- i'm trying to follow the wire from the toad connector back to the right turn bulb but hard to follow.
to trnfla: good idea- my wife says I just go in circles anyway.
cac43
mo
Posted: 05/19/12 08:47pm Link  |  Print  |  Notify Moderator
sorry forgot to say mh is a ford E450 chassis
enblethen
Moses Lake, WA
Posted: 05/19/12 09:07pm Link  |  Print  |  Notify Moderator
Slide down a little on this site. Diodes are about 1 inch square, about 3/8 thick with three wires. Blue ox diodes look very much the same.
The diodes maybe in trunk area or behind tailight assembly.
Roadmaster
Bud
USAF Retired
Suzuki XL7 pushing Pace Arrow
YC 1
Yuba City Calif.
Posted: 05/20/12 07:58am Link  |  Print  |  Notify Moderator
Just take the tail light assembly out or the panel covering it on the inside if there is one. Chasing ghost wires can be impossible. Skip all the imbetween stuff because it is not really important unless it is broken and then you can just run a new one if necessary using the old one as a tag line. Of course that is impossible if it is a ribbon type wire.
H/R Endeavor 2008
2007 Hummer H3 toad
Ranger Boat
cac43
mo
Posted: 05/20/12 03:25pm Link  |  Print  |  Notify Moderator
thanks for the info about the diodes. checked and they aren't behind the tail light assemblys.
enblethen_ thanks for the site from roadmaster showing the pix of diodes and as I read the page I realize that I'm way out of my league- when the saturn dealer wired the car to be towed with the roadmaster even brake system, he gave me back a package of something and said he did'nt need it- wrong! it was the brake switch thing mentioned in the roadmaster article. so in addition to the taillight problem i now realize I probably have any turnsignals when braking. so since the saturn dealer closed, I will go somewhere and get it all reconfigured. Thanks to everyone for the help.
