RV.Net Open Roads Forum: Class A Motorhomes: Tow Dolly and Chevrolet Tahoe?
 > Tow Dolly and Chevrolet Tahoe?
supercub
Modesto CA
Posted: 05/18/12 06:56pm Link  |  Print  |  Notify Moderator
I may end up towing a Chevrolet Tahoe to Texas, on a one way trip for the Tahoe. Since it's not set up for towing, I was thinking of a tow dolly. Does anyone know what's involved with towing a Tahoe with the rear wheels on the ground? Do you have to disconect the drive shaft or ?? I have no idea. Looking for suggestions and info. Thanks
Brian
rescue7
traverse city, mi
Posted: 05/18/12 07:27pm Link  |  Print  |  Notify Moderator
If its 4 wheel drive with 2 speed transfer case put transfer case in neutral and tow away.
Don & Lori
2007 Gulfstream Tour Master T40C
crasster
Dallas
Posted: 05/18/12 07:32pm Link  |  Print  |  Notify Moderator
What rescue7 said was good.
If you are renting the dolly, you can always consider a 4 up tow trailer too.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
gswcgi
Wandering
Posted: 05/18/12 07:37pm Link  |  Print  |  Notify Moderator
I had a 1988 Chevy Tahoe 4 X 4 and towed it for about 40K miles on all 4 down.I had to get a Remco drive shaft and to disconnect it when towing. It was a royal pain in the butt.
'03 Safari, DP, 36" Nissan 4X4 toad
mowermech
Billings, MT
Posted: 05/18/12 07:40pm Link  |  Print  |  Notify Moderator
You should probably check the Owners Manual to be sure, but for all the 4X4 vehicles I have owned, the Book specifically FORBIDS dolly towing!
However, you CAN probably tow it on a dolly IF you disconnect the rear drive shaft.
If it has a NEUTRAL in the transfer case, you PROBABLY can tow it four down.
Of course, you can always put in on a trailer, IF your tow vehicle can handle the weight.
CM1, USN (RET)
Toad: 2006 Jeep Rubicon LJ
1995brave
San Antonio, TX
Posted: 05/18/12 07:52pm Link  |  Print  |  Notify Moderator
Be safe. Disconnect the rear driveshaft. Removing four bolts is cheaper and easier than replacing a transmission or transfer case.
supercub
Modesto CA
I think a tow dolly possibly is NOT the way to go....so I'm thinking of a car trailer. Only place I can find to rent one, one way is Uhaul......and they're not sure if the Tahoe will fit. Penseke according to the website only rents a trailer to pull behind their trucks. Any idea where I can rent a car trailer for one way? Thanks
Brian
kaydeejay
SE Michigan, USA
Posted: 05/18/12 08:23pm Link  |  Print  |  Notify Moderator
Brian
Good luck finding one from U-Haul to carry your Tahoe. They wouldn't rent me one to carry a Buick Roadmaster back from Chicago a couple of years ago.
Said it was "too big"!
Keith J.
1999 Sunnybrook 27RKFS Fiver.
2005 GMC Sierra 2500HD CC/SB/DA 2WD, LBZ air cleaner, 52 gal Titan tank, Bilsteins, Line-X, Westin steps, Prodigy, Retrax cover, 16K Superglide, 5th-Airborne pin-box, Multi-vex mirrors, TST TPMS.
Executive
Posted: 05/19/12 12:13am Link  |  Print  |  Notify Moderator
Why not simply have it shipped on a carrier??? I used to use DAS to ship my hot rods and found them to be reasonably priced and efficient. Ship terminal to terminal for the cheapest rate. If you are not on a time table you shipping costs go down as they can simply add yours to another truck already enroute to Texas. Worth a call. Now if you're already going to Texas then that's a different story. You could rent a trailer round trip and bring back a car with you when you return and maybe make some money on the deal....Dennis
Dennis and Debi
Chevy HHR W/ ReadyBrute
Fourth Year Full Timing Click here to view our travel blog
