2 Retired
Myrtle Beach, SC
Cannot figure out how to connect Direct TV to our TV system. Here's a pic of the system's box.
Here's a pic of the back of the box:
Here is a picture of the front of the box. There is a coaxcable into the Satellite plug. I do not know where to put my satallite box.
edited 05/19/12 12:12pm by an administrator/moderator *
donn0128
Pronounced Ore-gun
Sat box needs to go between the switch box and the TV I would guess. Personally I would not use the switch box for sat. Take the cable off the switch, connect it to e sat box and then use either a HDMI or three wire connection from sat box to the TV.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
rolnhome
Casa Grande, Az
From dish to sat box out of sat box in to spliter box where it says sat in
We're in Arizona
Polishnurse
Schodack, NY
Looks like a Hurricane. But in any case you connect you satelite dish to the back of the satelite receiver as it was in your home. Then where it says TV Out, that goes to the back of the distruibution box (the one with all the buttons) where it says satelite in. Presto you connected. Select you front TV button, then Satelite and then you can check you set up.
This will allow you to switch from locale over the air to satelite, front and back TV - Bill
rvten
Crossville,TN
from Sat rec to Sat in on switch box.
Tom & Bonnie
Crossville, TN.
Aspect 29H 2008 Type C
Ford Flex SEL 2010
There is no B+
pulsar
Lewisville, NC
2 Retired,
I reduced the widths of your pictures to the forum's recommended maximum of 640 pixels. I deleted the attempt to post a third picture. The third picture would have been identical to the second one. It did not display because it had too many img tags.
This thread is moving from Forum Technical Support to Technology Corner.
Tom
2 Retired
Myrtle Beach, SC
Thanks Tom. All help is always appreciated.
Two young retirees restless to GO!
Life is too short to wait too long to do all we want to do!!
Go and enjoy!!
joeprinter
Fayetteville, NC
You can also connect your "Air Antenna" too Off Air connection on the back of your Direct TV receiver.. It will then pick up your air antenna channels at the same time (channel 3 or 4 on you receiver)
"2012 Forest River 360 DS"
"Ford V-10"
"2013 Toyota Corolla on Tow Dolly"
mikestock
Vestavia Hills, AL, USA
joeprinter wrote: You can also connect your "Air Antenna" too Off Air connection on the back of your Direct TV receiver.. It will then pick up your air antenna channels at the same time (channel 3 or 4 on you receiver)
That will depend on how old your receiver is. My oldest DVR has this feature but the newer receivers and DVR's do not.
2005 F250 Crew Cab LWB Power Stroke, 2007 Montana 3500RL Fifth Wheel,Honda EU3000IS, Twin Honda EU2000i's, S&W security system
Clay L
Sioux Falls, South Dakota
Many of the newer Direct TV receivers - my HR24 for example - do not have a coax input for off the air TV or for an output to the TV. In that case you would not be able to connect the sat receiver to the switch box without some sort of RF modulator.
Do you have coax output on your sat receiver?
Clay (WA5NMR), Lee (Wife), Katie (cat).
Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
