RV.Net Open Roads Forum: Travel Trailers: accidentally plugged in 240v to 120v camper....Help!!!
 > accidentally plugged in 240v to 120v camper....Help!!!
Page of 5
blondebluesfan72
Missouri
Posted: 05/19/12 02:33pm Link  |  Quote  |  Print  |  Notify Moderator
My husband decided to plug in our travel trailer which is a 120v plug into a 240v. outlets are working but microwave, refrig, and air conditioner are not.....did we just fry everything or can it be simply fixed??? we are new owners....of a used 1991 jayco 32ft eagle. Please help us so I don't kill him! ty
ladywendolyn
Canada
Posted: 05/19/12 02:36pm Link  |  Quote  |  Print  |  Notify Moderator
Check all your breakers on your breaker panel.. They may have flipped.
KD4UPL
Swoope, VA
Posted: 05/19/12 02:38pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry to hear about the mistake. I don't know how you could do that unless a standard RV 30 amp outlet were wrongly wired to 240 volts. Any normal 240 volt outlet shouldn't be configured in a way that would accept the trailer's plug.
I would bet the microwave is junk now. The refrigerator could probably be repaired with a new heating element. If the air conditioner was turned on it is also likely damaged. If it were off, maybe not. I would also check out your converter (battery charger) it was quite possibly damaged.
If you're lucky you just have some tripped breakers in the trailer. Have you checked them all yet?
Mandalay Parr
Phoenix, AZ
I'm afraid you fried. Better get an RV service guy to verify and start replacing the damaged parts.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
602-321-8141
pasusan
PA
Posted: 05/19/12 02:39pm Link  |  Quote  |  Print  |  Notify Moderator
Probably everything that doesn't work is fried. I've read it about it here a few times.
Good luck.
Trip Pics
"Don't let the sound of your own wheels drive you crazy." JB & GF
Susan & Ben ~
84 Bronco & 90 Award Classic 23 joined with a Hensley Cub
smkettner
Have you checked the converter and 12v power yet?
Fridge and air often need 12v to operate the controls.
Otherwise yes it could be expensive depending on how the survey goes. Some do better than others.
Here is an explanation of RV power. Click on the 30a page at top left.
http://www.myrv.us/electric/
Consider a power protection device.
http://www.progressiveindustries.net/ems_lchw30.htm
Somehow this is actually fairly common. So don't feel alone.
675 watts solar
HappyKayakers
Black River Falls WI
Posted: 05/19/12 02:40pm Link  |  Quote  |  Print  |  Notify Moderator
If the 110v outlets work, run an extension cord for the microwave to a known good outlet. If the microwave works on that, you may have lucked out and just need to reset/replace some breakers.
Joe and Dakota, the wacko cat
2006 Dodge 3500 QC CTD SRW Jacobs Exhaust brake
2006 Heartland Bighorn 3600RL, MorRyde suspension, TrailAir pinbox
http://happykayakers.com/blogger/
jwblock
Sussex Wisconsin
Posted: 05/19/12 02:42pm Link  |  Quote  |  Print  |  Notify Moderator
I hate to start with a question, but. Where did you get an adapter to go from an RV style male plug into a 240 volt outlet. You would have to make a pigtail for that.Was this at your house?
This may seem obvious, but check the ac breakers in the unit.
tvman44
Southwest Louisiana
Posted: 05/19/12 02:43pm Link  |  Quote  |  Print  |  Notify Moderator
Check all breakers in panel, fuses in the equipment and uncork your check book.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
downtheroad
Pacific Northwest
Posted: 05/19/12 02:51pm Link  |  Quote  |  Print  |  Notify Moderator
I don't dispute that you have an electrical problem...but I doubt that you plugged your rig into a 240v service.
Start checking breakers and don't forget the GFI's.
GMC Duramax LBZ
Komfort
Reese Dual Cam HP
Our Rig Picture...CLICK HERE
Page of 5
