JeffPritchard
San Diego California
My five-year-old Lance 1191 is holding up well in general, but this year I noticed that the vent for the kitchen fan has yellowed quit a bit and it doesn't look so great.
I was thinking about taking it off and painting it with some of that new krylon paint that is supposed to work well on plastic. Not sure if it will peel or otherwise disappoint after a couple years. Will I wind up wishing I had left it alone? Anybody tried that with yellowing plastic parts?
Any other ways you know of to bring it back to normal white color?
thanks!
Jeff Pritchard in San Diego
2008 Lance 1191 - 2005 Ford F-350 4X4 Diesel (paid for)
Wilderness Photographer - Click here to see my wilderness images
yankee camper
Rhode Island
I did exactly that last year on my vent.The Krylon paint was a perfect match and so far it isn't showing any signs of peeling. I have also painted latches and compartment doors with the same results.
Wanderin fool
Woodland Park, Colo.
I paint a lot of stuff and it sure helps the looks. I think the Krylon plastic paint is trash. I just use regular enamel on everything. A good brand is better than a chain brand ;Walmart, Kmart
ect. Rustoleum, Krylon,any name brand is usually better paint. I just scuff the surface with some scotchbrite to help adhesion.
Duramax/Lance 835
KTM/Arctic Cats
Motorized advocate in Colo. CMTRA, our local club.
www.cmtrail.org come visit!
Other Forums:
Thedieselplace.com ( chevsforever)
KTMtalk.com (xrcrasher)
Pontoonboating.com (Lounge Lizard)
Arcticchat.com (400crasher)
littlebigbar
Victoria, BC, Canada
i used regular enamel 5 years ago and it's still going stong (looks way better than the yellow sun-stained plastic). I washed everything with bleach first, and I think i replaced all the screws with stainless (if they weren't already)
Dave
'01 F350, SRW, CC, 4x4 longbox
Rancho 9000x, Firestone Ride-Rites, factory swaybars
'04 Bigfoot 9.6 and '96 Coleman Cheyenne (popup)
garlic
Marlborough
X2 on all of the above. Why they can't make a white that stays white is beyond me (but not beyond a can of spray paint).
NRALIFR
Truck Camping Out West
I'd paint it with regular Krylon or Rustoleum oil based paint, but I would not remove it. Just mask it off and use newspaper to keep the over-spray off the camper. The sun is what turned the plastic yellow, and it also makes it brittle. There's a very good chance that if you try to remove it, it will break.
2001 Lance 1121 on a 2010 F450
YC 1
Yuba City Calif.
Sometimes the cost of a rattle can of paint is more than it cost to replace the cheap plastic. Of course the RV store needs to be close.
H/R Endeavor 2008
2007 Hummer H3 toad
Ranger Boat
Emptypockets
North Central KS
Get you some good Citrus based cleaner & that will whiten it up.
AnEv942
CA
Dunno Ive had really good luck using krylon fusion paint for plastic.
But on the vent-I just replaced ours, though cause it was broke mostly. It was looking pretty bad was going to paint but broke before getting round to it. Under $10 localy, cheap but youll also need some putty tap & caulk. Im sure it will also need painting in a few years.
01 Ford 250 4x4 DRW Diesel, 01 Elkhorn 9U
Our camper projects page
tvman44
Southwest Louisiana
Clean it well and use krylon plastic paint.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
