RV.Net Open Roads Forum: Tech Issues: Shelf Life and AGM Question
 > Shelf Life and AGM Question
cruz-in
Southern Maryland
Posted: 05/19/12 06:07pm Link  |  Print  |  Notify Moderator
Hi All,
I know when shopping for wet cell batteries it is always best to buy ones that were made within the last few months. While probably still a good idea to get as fresh as possible, does the same importance of freshness apply to AGMs? i.e. Do not buy if more than 6 months old...
I thought I read that shelf life was much longer for AGMs....
Thanks
2oldman
Winchester WA
Posted: 05/19/12 07:15pm Link  |  Print  |  Notify Moderator
There are a lot of google hits on 'agm shelf life'
mena661
Posted: 05/19/12 09:20pm Link  |  Print  |  Notify Moderator
AGM's self discharge a LOT slower than flooded batts so they can sit without a charge (with no load of course) for quite a while, especially if they're kept relatively cool. Charging them every 3 months or so is not out of line.
Trojan L16 6V's 740 Amp-hours
bigfootford
Fair Oaks, California
Posted: 05/19/12 07:51pm Link  |  Print  |  Notify Moderator
Bestconverter has the Lifeline batteries he sells dropped shipped from lifeline...Not sure about the Universal's he sells.
Great prices too..
Might check with him.
http://www.bestconverter.com/AGM-Batteries_c_180.html
Jim
2000 2500 9.6 Bigfoot,94 F250, Vision 19.5, Mich 245/70XDS2's, Bilstein shocks, air bags/pump, EU2000, PD 9260,Lifeline 100ah, 200W. solar, Morningstar Sunsaver 15A/ display panel, Trimetric, Delorme/laptop, Holux gps rec,led lights, Wave-3 heat.
Almot
Vancouver BC
Posted: 05/19/12 10:15pm Link  |  Print  |  Notify Moderator
Subj - one year at least.
Wherever I happen to park
Posted: 05/20/12 05:04pm Link  |  Print  |  Notify Moderator
The fresher the better, No matter what the battery type.
tatest
Oklahoma Green Country
Posted: 05/20/12 05:23pm Link  |  Print  |  Notify Moderator
Are you asking about shelf life before or after activation? A number of brands/sizes of AGM are shipped dry, with electrolyte packaged separately. Those will store indefinitely until activated. They can be manufactured years before, but are "new" until the electrolyte goes in.
Once activated, shelf life starts. My experience, up to a year they seem to be OK. Two years storage without maintenance charging, they can lose service life or fail. The failure mode I am most familiar with is a cell shorting, often under heavy load only, which makes the fault hard to diagnose without load testing.
Even on a maintenance charger, 3-4 years is stretching expectations of the battery remaining useful.
My AGM experience is mostly small 12V AGM starting batteries, Japanese manufacture and Chinese clones; the clones do worse. Your experience might be different with larger AGMs of different design and application. Spiral-wound cells are a whole different territory.
PS. Was a time, 50's through 70's, flooded wet cells were shipped dry, filled (activated) when first put in use. I remember activating them, pouring acid from a PurePack wax container. I remember brands advertising this "freshness" as a feature. This may have been an older practice, we used to keep carboys of electrolyte around the shop when we did this type of general service. I suspect occupational safety standards led to wet cells being shipped wet.
* This post was edited 05/20/12 05:35pm by tatest *
Tom Test
Itasca Spirit 29B
2001 Ranger Edge
Jonesz
Minnedosa
Posted: 05/21/12 09:26am Link  |  Print  |  Notify Moderator
I have always been under the impression that AGM ie Absorbed Glass Mat batteries were sealed when they were manufactured. I did not think that there was any way to add electrolyte later and were basically hands off "maintenance free" If this is the case and the glass material is always impregnated with just enough acid at the factory to last the lifetime of the battery then I am thinking they come activated. That being the case I am thinking that the fresher the better as with most battery types. My AGM's are this type.
Jonesz
* This post was edited 05/21/12 03:31pm by Jonesz *
