RV.Net Open Roads Forum: Beginning RVing: I Don't Think I Am Thick...
 > I Don't Think I Am Thick...
Val0921
Georgetown
Posted: 05/20/12 03:52pm Link  |  Quote  |  Print  |  Notify Moderator
But trying to understand the inverter and converter and what works what is driving me nuts.
Has anyone else been slightly confused by all this?
Leslie
Wayne and Leslie
Georgetown, TX
2012 Winnebago Sightseer 36V
Our Furbabies: Monty, Little Guy, Smoke, Casey
Francesca Knowles
Port Hadlock, Washington
Posted: 05/20/12 03:59pm Link  |  Quote  |  Print  |  Notify Moderator
What's confusing is the terms, since they both actually describe a "conversion" process, but only one's called a converter!
CONverter "converts" 110vAC power to 12vDC. (In RVs, anyway...)
An INverter does just the opposite (the "inverse"???)- it makes 12vDC into 110vAC.
P.s.
As if that's not confusing enough- technically speaking, those "adapters" we all use at home for everything from answering machines to radios etc. are really doing the same thing as a converter- turning AC to DC., though of course not always to 12v. Sometimes they're also called "transformers"!
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
Allworth
Orlando, FL
Posted: 05/20/12 04:13pm Link  |  Quote  |  Print  |  Notify Moderator
Some very basics:
(There will be some, before you are done, who will provide much more technical explanations. They will probably add to your confusion, but they are really quite knowlegible about the electronics.)
CONVERTER
When you are plugged in to shore power:
CONverts 120Volt AC to 12Volt DC.
This runs most of the interior lights, ceiling vent fans, power jacks or landing gear, slideout motors, and the control boards for the fridge and water heater while they are on propane. All of these devices are 12Volt DC.
While it is providing DC power, it is also charging your battery(ies).
When you are NOT plugged in to shore power (towing or boondocking): the converter is doing nothing.
(Note that some devices such as the microwave, the air conditioner, wall outlets, TV, some lights, and the fridge and WH on "electric" run directly off of the shore line (fridge and WH still need 12Volts for control).
INVERTER
The inverter does nothing.
When you are NOT plugged in:
The INverter takes 12Volts DC from the battery and inverts it to a small amount of Sine Wave 120Volt AC to run such things as the TV or a laptop computer. Not much AC power and not for long unless you have a super bank of batteries and/or a solar charging system (some do).
There is usually a switch that connects one wall outlet to either the shore line or the inverter output (but never both at the same time. Bad things happen.) so you can use the inverter when off the power grid.
You will figure them out. It just takes a little time.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
2008 Titanium 30E35SA; EZ-Lube axles; wet bolts; spring hanger gussetts; BFG Commercial TAs
"Real Trucks Don't Have Sparkplugs"
HappyKayakers
Black River Falls WI
Posted: 05/20/12 04:26pm Link  |  Quote  |  Print  |  Notify Moderator
You can also get portable inverters in varying sizes (watts) so you can plug into your cigarette lighter in the vehicle, or 12v outlet in the RV and use small 110v appliances. You can find these at just about any truck stop or auto parts store.
Joe and Dakota, the wacko cat
2006 Dodge 3500 QC CTD SRW Jacobs Exhaust brake
2006 Heartland Bighorn 3600RL, MorRyde suspension, TrailAir pinbox
http://happykayakers.com/blogger/
K3WE
Missouri
Posted: 05/20/12 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
This is a pet peeve.
It's only according to RVers secret language that an inverter is not a converter. According to Websters dictionary a converter converts one thing to another, and if it's good enough for Websters, it's good enough for everyone.
Almost all campers have a built in converter to change 110 volts (yet another name for this is a rectifier that "fixes" the alternating current to direct current.
The "inverter" takes direct current and rapidly inverts it to make alternating current (along with stepping it up to 110 volts).
Dennis M M
Geneva, IL; Tucson, AZ
Posted: 05/20/12 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
More than you ever want to know right here: The 12 Volt Side of Life
'99 Volvo VNL610 - 425 HP Volvo; Super 10 Spd
'11 smart fortwo on Volvo
'05 Newmar Mountain Aire 35 BLKS
Trailer Saver; Bigfoot; Pressure-Pro.
Our Travel Blog - A New Adventure
Val0921
Georgetown
Posted: 05/20/12 06:09pm Link  |  Quote  |  Print  |  Notify Moderator
Can you all see my eyes going in circles? Lol. So I think I have the basics now thanks to all the great explanations.
Two more questions though:
Can I run things like our coffee maker while we are in motion?
Do all household items like laptops, hair blowers etc work off all outlets?
We have a cigarette lighter outlet by our dining table. I assume that's what you mentioned for charging cells etc when there is no shore line.
Thanks for all the responses, they were most helpful.
CA Traveler
The Western States
Posted: 05/20/12 06:47pm Link  |  Quote  |  Print  |  Notify Moderator
Val0921 wrote:
Can I run things like our coffee maker while we are in motion? Yes, however the safety aspects of hot water and a vehicle in motion should be considered.
Do all household items like laptops, hair blowers etc work off all outlets?Yes when on shore power or a generator. An inverter may only power some plugs. It all depends upon how your rig is wired.
We have a cigarette lighter outlet by our dining table. I assume that's what you mentioned for charging cells etc when there is no shore line. Yes, just like your car it can be used to charger or power various devices like a cell phone, rechargeable flashlight, etc.
2009 Holiday Rambler 42 Scepter with ISL 400 Cummins
2004 Honda CR-V
Bob
CA Traveler
The Western States
Posted: 05/20/12 06:56pm Link  |  Quote  |  Print  |  Notify Moderator
Be aware that running household appliances on an inverter can place a heavy drain on a battery. An 8A 120V AC coffee pot for example would cause a draw of about 88A from the 12V batteries.
Many rigs are better suited for lighter loads like watching a TV for a few hours.
beemerphile1
I'm 57, I'm not a
Posted: 05/21/12 05:49am Link  |  Quote  |  Print  |  Notify Moderator
The term inverter is used commonly across many fields. There really shouldn't be any confusion there.
The confusion is that the term converter is primarily used only in the RV industry, anywhere else it would be called a power supply. Some units combine the breakers, and fuses in the same cabinet. After doing that it is even more confusing because in reality it is a power center/power supply/battery charger all wrapped in one cabinet and called a converter!
- Soren Kierkegaard
