RV.Net Open Roads Forum: Tow Vehicles: 2012 Ford F-150 6 Ecoboost
Search only in Tow Vehicles
 > 2012 Ford F-150 6 Ecoboost
Konagirl
Napanee, Ontario, Canada
Posted: 05/20/12 03:57pm Link  |  Print  |  Notify Moderator
Will this truck pull a 29 foot Jayco Rdls?
Wills250psd
walnutcove NC
Posted: 05/20/12 04:01pm Link  |  Print  |  Notify Moderator
Is it the HD payload package? if so Yes if not you will have to post some weights and the exact 150 you have.
NewsW
US
Posted: 05/20/12 04:02pm Link  |  Print  |  Notify Moderator
Post the specs of the trailer and the specs of the truck.
Then post your willing to put up with bad handling, slow braking, and low acceleration.
Then lets do the math.
sh410
Northwest
Posted: 05/20/12 04:21pm Link  |  Print  |  Notify Moderator
29RLDS Weights
Unloaded Vehicle Weight (lbs) 7,175
Dry Hitch Weight (lbs) 955
Gross Vehicle Weight Rating (lbs) 9,500
Cargo Carrying Capacity (lbs) 2,325
therink
Rochester
Posted: 05/20/12 04:28pm Link  |  Print  |  Notify Moderator
sh410 wrote:
29RLDS Weights
Will it pull it? Yes.
Would I pull it with that truck? No.
Been there, done that and would not recommend it.
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5'er
2012 Silverado 3500HD, SRW,LTZ,4x4, Z71, Crew, 6.0 Gasser, 4:10 Gears, Standard bed
"These days, I have problems in areas that I used to not have areas", so life is good.
acadianbob
St. Paul, MN
Posted: 05/20/12 05:18pm Link  |  Print  |  Notify Moderator
sh410 wrote:
29RLDS Weights
Gross Vehicle Weight Rating will be 7,200, or 7,700, or 8,300 depending on the truck configuration.
Max Trailer Weight can vary widely depending on axle ratio, and whether equipped with Max Tow (or HD Payload) With Max Tow can be as high as 11,300. Typically about 9,200 or so with Regular Tow.
Payload ranges from 1,600 to 2,000 to 2,400
There are so many configurations that we would need to know how your truck is equipped to know exact figures.
You would probably be fine if you have MAX TOW and/or HD Payload. You would be very near (or above) your limited with regular tow.
Bob & Wendy; Spanky & Piper the Fox Terriers
2012 Race Red FX4 Ecoboost, Max Tow, Luxury Pkg
Surveyor 235RKS
Reese Dual Cam
ib516
Up here!
Posted: 05/20/12 05:49pm Link  |  Print  |  Notify Moderator
That will be one heck of a load for any f150. Too much IMO.
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
fla-gypsy
North Florida
Posted: 05/20/12 05:52pm Link  |  Print  |  Notify Moderator
Is the truck a Max payload, Max Tow version?? If yes then go for it, if not you will not have enough payload
BradinOhio
Akron, Ohio
Posted: 05/21/12 05:08am Link  |  Print  |  Notify Moderator
You need to run the numbers of the exact F150 model that you would be considering with the above TT weights (as camping, not dry brochure). Our new F150 (with maxtow package) has a GVWR of 7,650#, with 1,870# of payload, and a stated max towing capacity of 11,200#. Remember that the payload must account for all passengers, cargo, and the tongue weight of the TT and hitch. Good luck on your decision.
Brad ('68), Sandy ('71), Amber (shephard), Niko (shiba inu)
'12 F-150 XLT SuperCrew 4x4 Ecoboost with MaxTow
'12 Flagstaff V-Lite 30WRKSS
'10 Keystone Passport UL 245RB (prior - retired 6/2012)
'07 Rockwood Roo 21SS (prior)
Magblue10
Valparaiso, IN
Posted: 05/21/12 05:29am Link  |  Print  |  Notify Moderator
Like others said if you have max tow you should be fine the actual truck configuration would be helpful
