flathead92
Chandler AZ
Alot of new trailers have a flush system installed, then it don't matter.
mikem1945
Illinois
I have found the best tie downs are the type that screw in the ground and then use straps that can be pulled tight, such as straps you use to hold down when carrying things in your pickup.
MMiller
2005 Starwood SL 29ft RKS FW
2004 GMC 2500HD Ext Cab Duramax
therink
Rochester
Make sure after emptying black tank, always add about 5 gallons water to the tank before traveling home or using. This will keep the bottom of the tank wet, which keeps the odors down when in storage between trips. The tank will also then be ready for use on the next trip. I always keep about the tank about a third full. I don't dump until it is full.
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5'er
2012 Silverado 3500HD, SRW,LTZ,4x4, Z71, Crew, 6.0 Gasser, 4:10 Gears, Standard bed
"These days, I have problems in areas that I used to not have areas", so life is good.
HappyKayakers
Black River Falls WI
Oasisbob wrote: The reason for flushing grey tank last is the soapy water will help rinse the poop residue out of the hose as it goes.
I certainly agree with everyone about dumping the black tank only when it's mostly full. However, I'm going to suggest dumping the gray tank first. That way you get to check all your sewer connections and the integrity of the sewer hose. (How close did that guy with the weed whacker really get?). If there's a problem, you're only spreading gray water instead of black. It's a good practice to flush the black tank at least once after dumping and that will take care of rinsing out the sewer hose.
Joe and Dakota, the wacko cat
2006 Dodge 3500 QC CTD SRW Jacobs Exhaust brake
2006 Heartland Bighorn 3600RL, MorRyde suspension, TrailAir pinbox
http://happykayakers.com/blogger/
lj2654
weeki wachee, florida
Thanks Everyone!! That was QUICK response. Another ?. What type of Awning Tie downs do I need to purchase?
I use tie straps with the coated "s" hooks and metal screw-in dog posts
2001 Beaver Contessa Naples 40
2005 Honda CRV Toad
retired AirForce
therink
Rochester
lj2654 wrote: Thanks Everyone!! That was QUICK response. Another ?. What type of Awning Tie downs do I need to purchase?
X2 ratchet straps attached to each end of the roller staked into the ground when it is windy to stabilize the awning.
old guy
Oregon (pronounced Or e gun)
personally I wouldn't use the awning tie downs, if you leave for a hike per se, the wind may come up and rip the awning right off the side of the TT. if you are at the TT and the wind comes up, just roll up the awning and safe yourself some grief and money for that matter.
robsouth
Near Atlanta, GA
If it is windy enough to need "tie downs", it is windy enough to roll up the awning. I have seen an awning ripped from the side of the camper because the roller ends were tied down.
"Sometimes I just sit and think. Sometimes I just sit." "Great minds like a think."
Mont G&J
Missoula, MT
old guy wrote: personally I wouldn't use the awning tie downs, if you leave for a hike per se, the wind may come up and rip the awning right off the side of the TT. if you are at the TT and the wind comes up, just roll up the awning and safe yourself some grief and money for that matter.
X2 (Times two)
ExRocketScientist
Laurel, MD
The deflappers work better than the tie downs.
If you want to test the hose/connections with grey water, just let a little bit out. Then dump the black, followed by the remaining grey.
Some hoses rinse out better than others. The ones that act like a slinky don't rinse out as well as the high dollar ones that act like the bendable straws with the accordian section in them for bending (see hoses like the Camco Rhino-Flex or the Valterra Viper).
ERS
