Valkyriebush
Yuma/Port Townsend
X2 street atlas. Just bought 2012
to replace my older version. works great.
Command Master Chief (AW) USN, (ret)
2003 Fleetwood Excursion 330 Turbo Cat 39D
2000 Jeep GC
2005 Big Ruckus (Rides Behind Jeep)
2003 VTX 1800
hitchup
Fulltiming and on the Road.
As the navigator, I use MS S&T's to outline initial route with the help of iPhone Maps App because it will sometimes give us more alternatives and different driving times.
Then plug stops into Ford Navigation as we're driving. But sometimes follow along with iPhone Maps App using Current Location if we're in an unfamiliar location.
2009 DRV Mobile Suite 38TKSB3 (38RSSB3)....our custom home w/2011 upgrades
2010 Ford F450 KR CC 4x4......his office
Working Fulltimers since 3/2005
"Shoot for the Moon! Even if you miss it, you will land among the Stars."
zztinker
Central California
ipad does it all.........
2010 Jayco Eagle Super Lite 31.5RLDS Fifth Wheel, 2006 Ford 350 PSD SRW, long Bed, Champion 2000i inverter Generator and a Champion 3500/4000 Gen.
Sandy & Shirley
North East, MD
Be careful of GPS when towing. We have had two experiences where the GPS took us on a shortcut. Luckily there we no low bridges, but a few of the turns were fun at 55 feet long!
'02 F350 7.3PSD CC LB DRW, Reese 20K Hitch, Brake Smart, AirLift, C-betr mirrors,
'04 Everest 343L, TrailAir, RotoChoks, Wayne's stabilizer
Toys: Fold-Away Pet Carrier, Thermos Grill 2 GO
For more info, visit Our RV web site.
ddndoug
St Louis area
Can anyone tell me how the GPS portion works with your laptop? Or, can you just use the GPS that is on our phones? I was looking to buy a new GPS system (because I lost our old one, oops!) I like the thought of having the large screen of the laptop, but I would like to make it as simple as possible to use.
1996 Allegro 31M
F53 Ford chassis w/ 460 cid
enblethen
Moses Lake, WA
The Pharos GPS unit that comes with Microsoft Streets and trips plugs into a USB port. It is basically a GPS antenna only. S&T automatically detects it.
It can be used with other programs such as Trailer Life Directory software.
Bud
USAF Retired
Suzuki XL7 pushing Pace Arrow
NamVet3516CPL
home
Ok all this imput is great, thanks alot but which GPS do I need to use with Micro Soft Streets? I have the LT-40 (USB)for the Delorme but it is not seen by the software. I downloaded the trial version from MS. I have a Garmin nuvi 260w (older version) pluged in to USB and it too is not seen.
Thanks for all the help.
1775
NY
We have used both Streets and Trips and DeLorme and we prefer DeLorme. It certainly will do what you want. You start your routing with your home starting point and then put in your destination - THEN you go along the route and add your stops. It will route the trip completely stopping at all of the points that you have specified. Then save the route to your laptop and load it when you start your trip. For us DeLorme did this much better than Microsoft.
As to your question about what GPS to use with Streets and Trips - Microsoft sells a USB receiver with some versions of the software - just like the LT-40. The LT-40 should also work with Streets and Trips - make sure Streets and Trips has all of the settings correctly set for GPS routing.
Roadtrek 190 Popular 2011
Meryl and Me Hit the Road
ExRocketScientist
Laurel, MD
The laptop GPS units are extremely easy to use. They have a little receiver that plugs into a USB port and goes up on your dashboard. The DeLorme looks like a minurature mouse. Then you open the software application and tell it to fire up the GPS. Load any saved route setup you have and tell it to navigate. Then you are off. With the DeLorme, you turn the volume up a bit on the laptop and Anna (that is the default voice in Microsoft) will tell you when you have a turn coming up and what you need to do. You can also see yourself driving along on the screen. It is rather James Bondish. The DeLorme has WAAS capability and is extremely accurate. With the power of the laptop, it is extremely fast to sync up with the satellites and start giving accurate position. Much faster than a hadheld unit where you have to wait about 2 minutes if you haven't used it in a couple of weeks.
ERS
easlingn
I know this thread has been sleeping for a while but would like to add my 2 cents worth. I have been using the DeLorme GPS with Street Atlas since about 2001 and have been very happy with it. If you already have the lap top, you can have a great GPS system for about $50.00. I have tried several others and none of them compare.
Try this link for more info.
http://shop.delorme.com/OA_HTML/DELibeCCtpSctDspRte.jsp?section=10122
2005 Winnebago Journey 34 ft diesel pusher
1999 Jeep Grand Cherokee
