RV.Net Open Roads Forum: General RVing Issues: Should I buy a new tire?
 > Should I buy a new tire?
Ro646a
New Boston, MI
Posted: 05/21/12 07:17am Link  |  Print  |  Notify Moderator
The first thing I did when I purchased our "new" motorhome a couple of months ago was to buy new tires. Last weekend we took our first trip in it. Upon returning home I had to maneuver (sp?)around an island at the entrance to our subdivision, and accidentally hit a large boulder with the tip of my exhaust pipe. The pipe moved back against the tire, and one of the hanger brackets cut a 6" long 3/8" deep cut in one of the center treads on the tire. The cut is only about 1/3 the depth of the tread. I was about to go and buy a new tire, but I thought I'd first get some opinions here as to whether or not that is necessary. Any comment would be appreciated.
The good news here is that the boulder didn't hit anything else on the motorhome.
2001 Fleetwood Southwind 35R on 2000 Ford F53 Chassis
V10 310HP
Roadmaster Sterling All terrain tow bar
Ready Brake
2002 Chevy Tracker V6 4x4 SUV
hallock5
Posted: 05/21/12 07:30am Link  |  Print  |  Notify Moderator
Yes, I value peace of mind.
2008 Jayco Eagle Superlite 28.5RLS
2002 Ford 4x4 SuperCab 7.3 (Jr International) Diesel
Sad to say, time to sell to a good home.
FunnyCamper
Southeastern
Posted: 05/21/12 07:34am Link  |  Print  |  Notify Moderator
absolutely. like Hallock said, peace of mind and SAFETY
the price of one tire is not worth the trouble if something happens
Ozlander
Rose Hill, Kansas
Posted: 05/21/12 07:39am Link  |  Print  |  Notify Moderator
NO, if it's only in the wear portion of the tread. It will go away if you put enough miles on your coach.
I doubt if the tire guy would try to sell you a new tire, if you trust him, he would be the person to ask.
Ozlander
06 Yukon XL
2001 Trail-Lite 7253
Vulcaneer
Northern New England
Posted: 05/21/12 07:46am Link  |  Print  |  Notify Moderator
I wouldn't. You state the cut is in the tread only. And not the belts or strength structure of the tire. If that is the case, it will be fine. But the real questions might be, are you sure the cut is only 3/8 deep? How wide is the cut? Did it close up completely after being cut? Or is the some portion that is gouged out? So just be sure you know how deep the cut is. And if it is like you say, just run it and watch it.
It is a rear wheel and part of a dual set. So not likely a safety danger.
'12 F350 SB, CC, SRW, 6.7 PSD, 3.55 RAR, 6 spd auto, Ultimate Lariat pkg
2011 Open Range 393RLS 14,250 GVWR
Pullrite Super Glide 18K
Valkyriebush
Yuma/Port Townsend
Posted: 05/21/12 08:04am Link  |  Print  |  Notify Moderator
Tread only, nope. Side wall, for sure!
Command Master Chief (AW) USN, (ret)
2003 Fleetwood Excursion 330 Turbo Cat 39D
2000 Jeep GC
2005 Big Ruckus (Rides Behind Jeep)
2003 VTX 1800
trickyvic3
Raymond NH.
Mmmmm this is a tuff one to answer. I think if it were me I'd replace the tire. However, I'm anal when it comes to these types of things.
JMHO
Ro646a
New Boston, MI
Posted: 05/21/12 08:05am Link  |  Print  |  Notify Moderator
The cut is more of a gouge. It is about 1/4" wide and 3/8" deep and 6" long, on the edge of one of the treads. It is not a clean cut.
Vulcaneer
Posted: 05/21/12 08:15am Link  |  Print  |  Notify Moderator
On the edge of a tread....and you can be sure it is 3/8 deep....run it. But you will lose major points if entering into a tire beauty pageant.
FunnyCamper
Southeastern
Posted: 05/21/12 08:21am Link  |  Print  |  Notify Moderator
if in doubt, take it to the tire people. because it is not worth the total cost of the coach and your safety to even think it might be ok.
a tire vs. life and coach.
there is no contest.
