RV.Net Open Roads Forum: Tow Vehicles: Sorry state of fuel in North America
Search only in Tow Vehicles
 > Sorry state of fuel in North America
Page of 7
NavyDood
NW of DFW
Posted: 05/21/12 09:40pm Link  |  Quote  |  Print  |  Notify Moderator
NewsW wrote:
A lot depends on where you are, and the further north you go, the more problems biodiesel causes.
Depends on the blend.
NewsW wrote:
The problem is biodiesel quality is all over the map, and quality control is indifferent to ad hoc.
Sorry, but wrong. If it is retail biodiesel it has to meet ASTM standards. If someone uses any other type then shame on them for not knowing any better.
NewsW wrote:
Much of the issues I have documented --- on another thread --- with regards to corrosion from 2nd order metabolites, etc. which btw, was done by the US Navy.
And BTW the U.S. Military contracts biodiesel blends as their diesel supply on bases all across the country.
NewsW wrote:
At the end of the day, what you have done is to void the warranty as no on road certified vehicle is at present legally certified for B100.
Uneducated people is the problem, not the fuel if it is retail biodiesel.
NewsW wrote:
In any case, I see no rational arguments for biodiesel --- when the old fashioned diesel does the same job better and with fewer unknowns.
Keep convincing yourself of that.
NewsW wrote:
I, for one, like to have my emissions and warranties valid --- so I avoid uncertified use of biodiesel.
As of 2011 Dodge, GM and Fword are all B20 compatible. Cummins has approved/certified the HPCR ISB engine series for B20 since it hit the market in 03. Dodge didn't because of their lackluster filtering system. With the amounts of people that have run a biodiesel blend in the HPCR Cummins powered trucks where are all of the horror stories of those Bosch HPFP's failing in the Dodge trucks? Guess what? There are very few.
NewsW wrote:
If you choose to use it at your own peril --- that is your choice.
What Peril? I bought my truck used in 05 with 28,000 miles on it and I now have 182,600 miles. I started running biodiesel blends in 06 and haven't looked back. I have easily burned over 6000 gallons of biodiesel anywhere from B1-B100 and have never once had to change a fuel filter out of my regular schedule. My fuel filter change only happens when I see a consistent drop in pressure to around 15 psi from my normal 21 psi.
* This post was edited 05/22/12 08:31am by NavyDood *
- Retired Navy Chief
- Vanilla 04 2500 QCSB, 4x4, 48RE w/MagHytec DD, Smarty Jr, 4" Exh, Modded Air Box, Isspro Gauges, Quadzilla RPG w/fuel pressure, DynaTrac front, Coolant By-Pass Filter
- 06 Pilgrim 30RE2SLF-5 13,300lbs loaded. B&W Companion
NewsW
US
Posted: 05/21/12 09:48pm Link  |  Quote  |  Print  |  Notify Moderator
We have to agree to disagree.
ASTM standards is the joke on user out there.
There is no enforcement of the standards across the board at the retail level.
No consistent, nationwide, independent testing and sampling.
Nor is the standard itself sufficiently robust even if all fuel met standards --- it keeps evolving to add new issues as it is discovered.
At the retail level, ASTM is an aspirational standard that is akin to an API oil grade --- compliance and enforcement is entirely voluntary.
* This post was edited 05/21/12 10:09pm by NewsW *
Ron3rd
Upland, CA USA
Posted: 05/21/12 09:59pm Link  |  Quote  |  Print  |  Notify Moderator
boondockdad wrote:
doesn't help many east coast refineries are going off-line
thanks barry!
And the govt is supposed to tell them not to go offline? If you took the time to get educated about the subject, you'd find the Govt, Dem or Republican has very little (virtually zero) control over the price of gas.
2004 Aljo 250LT
Eaz-Lift WD Hitch
Single Friction Sway Control
Prodigy Brake Controller
Honda EU2000
ped
cincinnati
Posted: 05/21/12 11:05pm Link  |  Quote  |  Print  |  Notify Moderator
Oh crude dropped below $100? Well the we're going to need a few more stories about Iranian threats. That'll take care of that.
NewsW
US
Posted: 05/22/12 05:11am Link  |  Quote  |  Print  |  Notify Moderator
Off hand... would anyone like to tell me how they evaluate the quality of gasoline / diesel / other fuels?
coolbreeze01
Redding, Ca
Posted: 05/22/12 07:51am Link  |  Quote  |  Print  |  Notify Moderator
^^^^^^A Chevron sign and clean restrooms for starters.......
2008 Dodge 3500 With a Really Strong Tractor Motor...........
LB, SRW, 4X4, 6-Speed Auto, 3.73, Prodigy P3, Blue Ox Sway Pro........
2007 Komfort 212 on 225 75R 15E Maxxis ST Tires.........
Charlie D.
E. Texas-Orange
Posted: 05/22/12 08:06am Link  |  Quote  |  Print  |  Notify Moderator
Not saying that fuel is not filtered at stations but I question how often they are changed to prevent one from receiving contaminated fuel.
Compare the number of times you fuel up versus the number of times the pump is turned up and then think about the number of times you have seen a cover off the pump and someone changing a filter that is not much larger than the one on your pump. Seems to me that filters would need replacing at least once a week and I don't see that happening. Only time I see a cover off a pump is when someone is doing a repair and the nozzle has a plastic bag over it because it was taken out of service
Enjoying Your Freedom?
Thank A Veteran
Native Texan
Snow_King
Gold Canyon, AZ
Posted: 05/22/12 08:29am Link  |  Quote  |  Print  |  Notify Moderator
Well, I thought only diesel was filtered at most retail outlets. Never seen a filter on a gas pump!
Somewhere in a Fifth Wheel - Where it does not Snow
NewsW
US
Posted: 05/22/12 08:33am Link  |  Quote  |  Print  |  Notify Moderator
Filtering, depending on the specs of the filter, can block particles.
Some can hold back water to a point.
But filtering used at retail stations cannot block liquid or gaseous contaminants.
Charlie D.
E. Texas-Orange
Posted: 05/22/12 10:59am Link  |  Quote  |  Print  |  Notify Moderator
I also have never seen a filter on a gas pump but I have also never seen anyone replacing filters regardless of type of fuel.
I stopped at a station where new pumps were being installed and asked about filters. Guy doing the installing said they have filters in the top section before the nozzle.
Page of 7
