RV.Net Open Roads Forum: Class A Motorhomes: Towing
 > Towing
UL Alum93
new iberia, la
Posted: 05/21/12 12:54pm Link  |  Quote  |  Print  |  Notify Moderator
I am setting up my Jeep to pull and am looking for suggestions for portable lighting. I use a bike rack on the back of the Jeep which hides the stock Jeep lights so I need a bar or portable lights. Suggestions on particular ones or ways around this issue.
Tom N
Sarver, PA/Crystal River, FL/Shelocta, PA
Posted: 05/21/12 02:02pm Link  |  Quote  |  Print  |  Notify Moderator
I use magnetic lights from Harbor Freight and install them on my roof. Lights are often on sale for $9.95. I run the wiring through an open door and then out and under the hood. I also bought a flat 4 pin to round 7 pin adapter to plug the lights into my motorhome from Walmart for $10.
-Tom
Sarver, PA/Crystal River, FL/Shelocta, PA · W3TLN · FMCA 335149 · Mystic Knights of the Sea
2005 Suncruiser 38R · W24 chassis, no chassis mods needed · 2012 Honda Accord EX-L · 2008 Honda Odyssey EX-L
UL Alum93
new iberia, la
Posted: 05/21/12 02:33pm Link  |  Quote  |  Print  |  Notify Moderator
Tom,
If you use the magnetic one, how does it stay on your hard top which is fiberglass?
bsinmich
Holland, MI
Posted: 05/21/12 02:43pm Link  |  Quote  |  Print  |  Notify Moderator
Back when I towed a Sundance on a dolly I made a wooden bar with the suction cups and bracket from an old roof top carrier and attached the lights to that. I used a couple of straps to secure it to the trunk lid.
2003 Newmar Mountain Aire, Workhorse W22, 2008 Saturn Vue, Falcon 5250, & US Gear Unified Tow Brake
Ed C
Cape Cod, MA
Posted: 05/21/12 03:22pm Link  |  Quote  |  Print  |  Notify Moderator
I use Boat Trailer Sealed LEDs. I attach then with HD Velcro and where they might be a little insecure I also use wire ties (the're cheap and work well). The LEDs are bright enough to mount inside tinted glass.
Ed/Jeanie & Slade the GSD
2010 Journey 40L/ Sierra Crew
wa_desert_rat
Central Washington State
Posted: 05/21/12 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
UL Alum93 wrote:
Tom,
He *could* use a flat piece of steel inside the Jeep with the fiberglass roof sandwiched between them.
Craig
Ron8877
Blaine, Washington or wherever we park
Posted: 05/21/12 07:52pm Link  |  Quote  |  Print  |  Notify Moderator
On the back bumper of my Jeep are a couple of things that stick out to the rear. I mounted LED lights to these and then ran the 4 strand wire to the mh plug.
Ron
Ron & Ali Workentin
www.ali1257.blogspot.com
Tom N
Posted: 05/22/12 11:54am Link  |  Quote  |  Print  |  Notify Moderator
UL Alum93 wrote:
Tom,
The roof of my car is steel.
-Tom
gone2dadesert
Encinitas, Ca
Posted: 05/22/12 05:24pm Link  |  Quote  |  Print  |  Notify Moderator
I carry Harbor freight tow lights just in case...
2011 Hurricane 31J
2008 Jeep JK Unlimited Rubicon
wny_pat
Western NYS
Posted: 05/22/12 05:41pm Link  |  Quote  |  Print  |  Notify Moderator
When I had my Swagman bike rack, I mounted stop, turn, tail LED lights to the bike rack. They plugged into the trailer light outlet on the back of the car. That way no body, including a LEO, could say that my rear lights were obscured by anything. It was a light like the following with a rubber gasket around it.
 > Towing
