RV.Net Open Roads Forum: Truck Campers: Superhitch Question
 > Superhitch Question
Ranger Smith
Wherever the rig is parked
Posted: 05/21/12 02:25pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2 1/2 inch and a 2 inch receiver on my truck. The 2 1/2 inch is below the 2 inch. Would you use the torklift extension with the double 2 inch bars and use a adapter in the 2 1/2 inch receiver or would you use the 2 1/2 inch single bar that is sold for trailers.
Where I Am Now
Amateur Radio Operator KK9W ARRL VE FT DX2000
Steve and Joy
1999 Winnebago Ultimate Freedom
2011 RAM 1500 Laramie CC 4x4 Hemi
Yogi . . . The Yorkie
Kage . . . The Poodle
Cookie . . . The Chihuahua
Cooper . . . The Aussiedoodle
Super_Dave
Sacramento, CA
Posted: 05/21/12 02:28pm Link  |  Quote  |  Print  |  Notify Moderator
The length of extension required and what you are pulling will dictate which is best.
Truck: 2006 Dodge 3500 Dually
Camper: 2007 Eagle Cap 850
Boat: 2003 Jetcraft 2125 - Yamaha 150 HP & 8 HP Kicker
Ranger Smith
Posted: 05/21/12 02:49pm Link  |  Quote  |  Print  |  Notify Moderator
Need 48" length and will be pulling an 18 foot Stingray boat on occasion and also a 6 x 10 utility trailer with some tools in it
Super_Dave
Sacramento, CA
Posted: 05/21/12 03:04pm Link  |  Quote  |  Print  |  Notify Moderator
Sight unseen, I'm going to say that 48" automatically calls for a 2 1/2" extension. Can we see a picture of how these 2 hitches are working together?
Gripnriprod
Alaska
Posted: 05/21/12 03:17pm Link  |  Quote  |  Print  |  Notify Moderator
I would use the torklift extension with the double 2 inch bars and use an adapter in the 2 1/2 inch receiver. What hitch do you have that has two different size receivers? Answered my own question - you must be running the Magnum model.
* This post was edited 05/21/12 03:29pm by Gripnriprod *
'11 GMC 3500hd SLT DRW D/A 4x4 Spray-in, Air Bags w/comp & controls, TL, Superhitch, 48" Supertruss, 9.5t Warn, front rcvr, Fox Shocks, '11 AF 1140, DB, AC, Gen, Solar, Thermal Windows, Wardrobe, Rear & Side Awnings, 18' Lund/40hp Honda 4 stroke
Specularius
Deville, La
Posted: 05/21/12 03:27pm Link  |  Quote  |  Print  |  Notify Moderator
I would think someone installed your hitch upside down. The 2 1/2 is supposed to be on top.
2011 F-350 DRW 6.7 Scorpion Diesel Reese Ford Hitch
2008 Bristol Bay 3420
2006 Okanagan 117DBL
Ranger Smith
Posted: 05/21/12 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
I have a factory 2" hitch on top. I also have a CURT class V on the truck it is designed to mount right below the factory 2" hitch which it does. I can use either a 2" receiver or a 2 1/2 inch receiver. That is why the question about the extension bar. What is best?
Steve
Reelescape1
Charleston
Posted: 05/21/12 06:28pm Link  |  Quote  |  Print  |  Notify Moderator
Mine's 2 and 2. The top one is the receiver, the bottom is the "stiffener". If that's the case and you had to use a spacer, the stiffener is probably the better.
Specularius
Deville, La
Posted: 05/21/12 08:00pm Link  |  Quote  |  Print  |  Notify Moderator
Steve
With that being the case, I would get the 2 1/2 inch super truss and when assembling it put the 2 inch stiffening tube on top of the 2 1/2 inch tube.
johnnycap
Pocono Mtns.
Posted: 05/22/12 06:05am Link  |  Quote  |  Print  |  Notify Moderator
Steve
I have the same hitch set-up and use a Reese Titan 2 1/2" extension into the Curt receiver.
'06 Ram 2500 4WD Quadcab SB Laramie, Cummins
SuperSprings, Timbrens
Nitto Dura Grapplers 3970 Lbs
2010 Covered Wagon
2010 GoldWing
2013 Work and Play 30 WRS
