RV.Net Open Roads Forum: Class A Motorhomes: Terrible RV Crash in Phoenix
 > Terrible RV Crash in Phoenix
goldviper
Gilbert, AZ
Posted: 05/21/12 10:43pm Link  |  Print  |  Notify Moderator
A really bad RV crash in Phoenix today.
http://www.azfamily.com/news/1-dead-several-injured-in-motor-home-crash-on-Loop-202-152361365.html
Les
docj
Fulltime--Home is where we park it
Posted: 05/21/12 11:06pm Link  |  Print  |  Notify Moderator
The news report says that a front wheel blowout resulted in the RV striking the Jersey barrier.
Sandie & Joel
2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12
2009 Chevy Malibu LTZ with ReadyBrute tow bar/braking system
Official WiFiRanger Ambassador WFRAMB303
Follow our adventures on Facebook at Weiss Travels
sdianel
Tampa, FL
Posted: 05/21/12 11:28pm Link  |  Print  |  Notify Moderator
so sad. Hope the children are ok.
Lonny & Diane
2004 Country Coach Allure 33' "Big Blue"
Towing 2008 Chev Colorado 4x4
Semper Fi
Alpenliter
Fulltimer: Wherever we are!
Posted: 05/22/12 12:22am Link  |  Print  |  Notify Moderator
Clicky
My first Wife Linda, 45+years
2004 F-450 CC, DRW 6.0 Classy Chassis Upgrade
Bulletproof Diesel upgrades
1997 33' Alpenlite
400 Watts Solar
Lifetime Good Sam Member #39644174
Escapees SKP#89882
Vietnam Vet '67-'68
Extreme Makeover RV Style!
1bigfatcat
Posted: 05/22/12 12:30am Link  |  Print  |  Notify Moderator
As a female driver of a 40' DP, what should I know/do if I have a front tire blow out while driving?
kjburns
Prescott, AZ
Posted: 05/22/12 12:53am Link  |  Print  |  Notify Moderator
There is a video out by Michelin. I found it here. Watch it and you'll be better prepared. The instructions are counter-intuitive.
2011 Winnebago Tour 42QD
past-MIdirector
Michigan
Posted: 05/22/12 06:10am Link  |  Print  |  Notify Moderator
Those poles along the mediums can cause way to much damage to any vehicle that is much larger than the retaining wall. Never through about how much damage can happen when they add things other into a retaining wall.
rgatijnet1
Posted: 05/22/12 05:07am Link  |  Print  |  Notify Moderator
I've been driving for a lot of years, going back to when recaps were common and tires all wore out before 12,000 miles. One thing that I learned was that with a blowout the best reaction was to accelerate slowly and hold the wheel steady. When things have stabilized, slowly start to pull off of the road, or any safe area. DO NOT touch the brakes. Let the vehicle slow down itself. DO NOT worry about any damage to your wheel or coach. It can all be repaired.
The best thing is to just be prepared NOT to over-react when you hear the loud bang, or feel the coach start to get mushy. Blown out tires are really not that big of a problem. Anyone that has watched any of the chase scenes on the TV news know that the criminals can still drive pretty good even after running over the spike strip with one, two, or even four, flat tires. It takes a little more of your attention, but it is something that is easily dealt with, IF you are prepared.
fla-gypsy
North Florida
Posted: 05/22/12 06:46am Link  |  Print  |  Notify Moderator
It is very hard to prepare for an event like this. Being attentive at all times to what you are doing and what is going on with the vehicle when you are the operator is the best defense. Sometimes you will get a short indication of a problem before a tire fails (vibration) sometimes you don't. The thing you cannot do is jerk the wheel hard and slam on the brakes when it happens. That is a recipe for a crash. You lift from the accelerator, keep it as straight as possible and let it slow down to a safe speed before attempting to brake lightly and get it stopped.
pusherpilot
Wherever we are.
Posted: 05/22/12 08:39am Link  |  Print  |  Notify Moderator
Another testament to keeping an eye on your tires and replacing them when they're too old to run safely. This man may have done all those things but in the case of a blowout, that's all any of us can do. The account says that it was a LF blowout so that means there was probably a witness that saw it go before the crash.
Ron
