I don't see any reason why you can't rotate the base to find firm wood.
If you go the toothpick and glue route note that some toothpicks have a waxy surface and glue won't adhere well. I have also found that white carpenters glue doesn't work well for this purpose as it's not gap filling. Use epoxy as someone mentioned.
You could also epoxy a piece of solid wood to the particle board and screw into that. It would of course raise the table a small amount.
Rotating it to fresh wood seemed to work. I put a little dry lube on the legs to help prevent it again. That thing really gets snug. Not crazy about that dinette design. Anyone ever done a conversion from the legs on the table to something else? Only other design I've seen with that type of dinette is the hinged top and one collapseable leg. I think they wobbled a bit if memory serves.
All good suggestions here. We just rotated the base a little and found new wood for the screws. It has worked well for over 4 years now.
Camping Rig:
2005 Dodge 3500 - Dually- Cummins
2006 Outback 27 RSDS
We also have with us two "fur babies". A Basset Hound and a Chihuahua mix. Both are rescue dogs.
particle board was designed to save trees I think and use the scrap. this is a good and poor idea but usually works ok.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
In my old 1975 Taurus TT the tables had a slotted rail mounted to the wall and a mating piece on the table. The table was solid. The only problem was the table had to be lifted out of the slot so it could be used as the bed platform. I have seen this system occasionally on the WEB. I liked it but it was a PITA when making it into a bed and I could not use it any more due to physical problems.
U. S. Navy (RETIRED) 1993
1995 Gulf Stream Scenic Cruiser 34' Diesel Pusher Cummins B5.9 12 Valve Engine, Allison MD-3060 6 Speed Transmission.
TOAD: 2005 Ford Focus Automatic Station Wagon
Road Master Sterling All-Terrain
