Tile man
I replaced my Onan RV 4000. I have no complaints. The old one gave me many thousands of usage hours.
The 50 hour break in oil change is due. I'm thinking about using 10-30 full synthetic oil.
Does anyone have a comment on this subject?
Thanks
jauguston
Bellingham, WA
The only comment that really matters is Onan's. What do they recommend?
Jim
2005 Coachman Sportscoach Elite 402 40'
350hp Cat C-7 w/MP-8
7500w Onan quiet diesel generator
6-Kyocera 130w solar panels SB3024i MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
Clay L
Sioux Falls, South Dakota
Over the last couple of years several people have said/posted that they talked to Onan customer service and were told it was okay to use synthetic oil. I started using Mobil One 10W30 in my mine last year (along with my engine). No problems so far.
Clay (WA5NMR), Lee (Wife), Katie (cat).
Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
Terri21
Newfoundland
Clay L wrote: Over the last couple of years several people have said/posted that they talked to Onan customer service and were told it was okay to use synthetic oil. I started using Mobil One 10W30 in my mine last year (along with my engine). No problems so far.
..I also have been using Mobil One full synthetic 10W30 and have noticed faster starts, quieter operation and am pleased with it so far...had asked at an Onan repair shop and was told it should be fine...also running full synthetic in my RV engine...a 6.6L Chev..
Gau 8
United States
Use what the manufacturer recommends. Especially under warranty.
mlts22
Austin, Texas
I like running full synthetic in generators if at all possible, just because newer ones are splash lubricated, so the little oil the genset uses is put through heavy use. Might as well use the best.
W4MBG
Williamsburg, VA
isn't it supposed to get SAE30 or 15W40? i would go with the 15W40 rotella (or mobil-1 after break-in).
1999 Winnebago Minnie, 29', Triton V10, mostly stock. So far...
Clay L
W4MBG wrote: isn't it supposed to get SAE30 or 15W40? i would go with the 15W40 rotella (or mobil-1 after break-in).
My manual says SAE30 is good for the temp range I tend to stay in but says 10W30 is okay for wider temp ranges.
From the Onan manual:
TABLE 1. OIL VISCOSITY VS. TEMPERATURE
EXPECTED AMBIENT SAE VISCOSITY
TEMPERATURES GRADE
32° F (0° C) and higher .........30
10° F to 100° F (-12° C to 38° C) 15W-40
(OnaMax™)
0° F to 80° F (-18° C to 27° C) 10W-30
10W-40
-20° F to 50° F (-28° C to 10° C) 5W-30
