RV.Net Open Roads Forum: Beginning RVing: Brake controller
 > Brake controller
safn1949
Mankato,MN
Posted: 05/22/12 09:21pm Link  |  Print  |  Notify Moderator
Ok,now for a really dumb question........I have a 1999 Dodge 3500 cummins dually towing a 1991 wilderness 27G. The trailer is parked for now and I am fairly sure I need to install a brake controller for the trailer brakes.
The truck has tow package and all that but no way to activate the brakes without a controller......am I correct?
Thanks for the help.
jjotmo
St Johns Mi
Posted: 05/22/12 09:40pm Link  |  Print  |  Notify Moderator
Correct you need a brake controller. FWIW i love my prodigy p2 it is great
RCMAN46
NorthWest
Posted: 05/22/12 09:54pm Link  |  Print  |  Notify Moderator
If you go with a Prodigy get the cable for your dodge. Then it is simple to install. The electrical is then just plug and play.
I prefer the P3 because of the extra diagnostics and the current reading.
Beartoo
Perham MN
Posted: 05/23/12 03:43am Link  |  Print  |  Notify Moderator
safn 1948
I have sent you an email about a P3 I have for sale, if you are interested.
Take Care,
Beartoo
DH - Bear
DW - Marge
Buster - English Springer Spaniel
Molly - English Springer Spaniel Puppy
07 Silverado 2500HD, Dmax, Allison Trany
Husky 15K
2008 Wildcat 24RL (Old Camper)
2009 Open Range 280 RLS (New)
gjwarneke
Vancouver, wa.
Posted: 05/22/12 10:53pm Link  |  Print  |  Notify Moderator
x2>>>>>Prodigy 2
anaro
Mebane, NC
Posted: 05/22/12 10:59pm Link  |  Print  |  Notify Moderator
Yes you absolutely need a brake controller. Get a proportional brake controller not a time delay. I loved my prodigy P3. The only difference between p2 and p3 is the p3 has better diagnostics and I think set up a little better for quick use. As stated above her the dodge specific wiring harness and it should install in less than 10 min if your truck is prewired for a brake controller.
2009 Ford F250 Lariat Crew Cab 6.4L diesel 4WD
2011 Crossroads Zinger ZT26BL
Reese Dual Cam
6 nights camped in 2013!
21 nights camped in 2012!
27 nights camped in 2011!
DE88ROX
West Michigan. The other West Coast
Posted: 05/23/12 07:39pm Link  |  Print  |  Notify Moderator
I believe the Dodges and Fords all come pre wired (harness connector) for a break controller. My GMC was pre wired but with open ended wires. Just mount it, plug it in and your good to go. The p2 comes with a default setting of 6.0. I just left mine at that and it seems to be working. dont feel the trailer pushing me at all.
Like others have said, go with the Prodigy2. Its very simple to use and also gives a digital reading of how much current is being applied to your TT breaks.
Im in no wau shape or form a mechanic and if I can get this hooked up right...anyone can.
TV- 2010 GMC Sierra Z71 EXT. cab
TT- 2012 Starcraft Autumn Ridge235fb
talonhead
SE CT
Posted: 05/23/12 08:23pm Link  |  Print  |  Notify Moderator
Just got back from my first trip with my 5er, and prodigy P3. OUTSTANDING!
3 levels of boost control, manual trailer brake control and air/hydraulic compatibility make it a cinch.
MikeH
 > Brake controller
