JaneNLee
Las Vegas, Nevada
Has anyone used the 'Hott Rod Water Heater Conversion Kits' to convert gas Water heating to gas/electric water heater?
Or is there any other type you have used to convert from gas only to gas/electric?
Any ideas or help will be appreciated.
Thanks in advance for your help.
Have a nice Memorial Day weekend.
Jane and Lee
Never RV with anyone crazier than you!!
fordsooperdooty
HottRood has been selling those things for many years, we have used them in the past when we had a propane only water heater a couple of Jayco's ago...worked great!
edited 05/22/12 09:57pm by fordsooperdooty *
JaneNLee
Las Vegas, Nevada
Thanks fordsooperdooty- did you install the HottRod? or have a mechanic do it?
fordsooperdooty
DIY...very easy. Basically screw it in and supply it with 120 volt electricity. They work on Atwood and Suburban Water Heaters.
Atwood has an aluminum tank that won't rust, the Suburban has a glass lined tank and a anode rod to keep rust away.
Old-Biscuit
Across the USA
fordsooperdooty wrote: DIY...very easy. Basically screw it in and supply it with 120 volt electricity. They work on Atwood and Suburban Water Heaters.
They install in the drain.......if using on a Suburban that needs an anode (which is part of drain plug) how do you provide for corrosion protection?
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
Francesca Knowles
Port Hadlock, Washington
Those things are great- but don't expect the same performance as from an as-built 2-way...the conversion's only 400 watts as opposed to (I think) 1200 in an as-built.;
Good point about the anode- The Hott Rod kit for Suburbans does contain an anode, but those who buy the Camco unit will need to make other provisions. Some folks put the anode where the existing pressure relief valve is, and move the p.r. valve to the "hot out" wherever it fits inside the RV (teed/y'd for outflow).
Save that anode, folks- you'll be saving your tank!
edited 05/22/12 11:59pm by Francesca Knowles *
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
philandterri
Westtown, NY
We installed the HOT ROD in our Atwood heater in 1998 and still have it today. Besides the rod going in the drain hole, you have a thermostat control that you stick on the tank and need to have electic connection nearby. We run an extension cord from the water heater to an outlet. We clean the scale off the rod about every six months.
gotsmart
Aberdeen, WA
My RV tech won't install the electric conversion kits. He says that the water heater MFGs void the warranties if electric conversion kits are present at the time of warranty service. He seemed to imply that it was also an insuarnce liability issue for his RV service business as well.
2005 Cruise America 28R (Four Winds 28R) on a 2004 Ford E450 SD 6.8L V10 4R100
2009 smart fortwo Passion with Roadmaster "Falcon 2" towbar & tail light kit - pictures
JaneNLee
Las Vegas, Nevada
Thanks everyone for your help!!! Have a great Memorial Day weekend....
