RV.Net Open Roads Forum: Class C Motorhomes: Mirrors
 > Mirrors
magik235
Central Wisconsin
Posted: 05/22/12 10:57pm Link  |  Quote  |  Print  |  Notify Moderator
I currently have two of the standard rectangular mirrors with a convex auxiliary mirror in the lower outside corner of both mirrors. I am not completely satisfied with my field of vision. What is the best mirror setup?
1985 Sport Coach http://www.rv.net/forum/index.cfm/fuseac........d/tid/26101292/srt/pa/pging/1/page/1.cfm
Replant
Someplace
Posted: 05/23/12 03:10am Link  |  Quote  |  Print  |  Notify Moderator
Sounds like you need a rear view camera. I have one with a 7" monitor to which I added a second camera that is mounted under my right side mirror. It gives me a clear view of everything on the side and to the rear. It should come in real handy when changing lanes and making right turns.
magik235
Central Wisconsin
Posted: 05/27/12 09:02pm Link  |  Quote  |  Print  |  Notify Moderator
I removed the stick on wide angle mirrors then mounted separate wide angle mirrors below the regular mirrors. The field of vision is greatly improved.
j-d
Sunny Florida USA
Posted: 05/27/12 09:09pm Link  |  Quote  |  Print  |  Notify Moderator
Hard to understand exactly what you have from your description. Most later model E-Series have the single-arm power mirrors but we have the rental-truck-style tripod mirrors and I did this
On a 1985 E-Series, you probably have the "west coast" style mirrors mounted on a hoop-like bracket. Adding a large convex mirror there is very easy.
God Bless, jd
2003 Jayco Escapade 31A on 2002 Ford E450 V10 4R100
Replant
Someplace
Posted: 05/28/12 10:25am Link  |  Quote  |  Print  |  Notify Moderator
This is how I mounted the side view camera.
Handbasket
Asheville, NC
Posted: 05/28/12 11:24am Link  |  Quote  |  Print  |  Notify Moderator
Simple cure.... from the Tiger's driver's seat, . Note that the short little Forester's rear side is still visible in the spot mirror, even tho' the front is well visible thru the window. Costs about $3 at an auto parts store. Look for the ones where the fisheye spot swivels a little in the stick-on base. No extra drag or wind noise with this.
Jim, "Dark matter happens."
'06 Tiger CX 'C Minus' on a Silverado 2500HD 4x4, 8.1 & Allison (aka 'Loafer's Glory') www.tigervehicles.com
 > Mirrors
