Cedarhill
Deep South
Our travel trailer that is somewhat larger and probably more power hungry than yours. We have more than one battery but a single Group 27 12V Interstate deep cycle battery lasts us one night plus a little reserve and we are only moderately conservative. I would not want to go somewhere like Alaska without at least one additional reserve battery. Even with a spare, you will need to run your generator for several hours every other day to keep up.
smkettner
How warm is the thermostat overnight? Put it down closer to 60-65 (or less) (or off)
The 7155 is a slow charging converter. What generator do you have?
You should make it with one group 27 but you need a better charging system.
Consider getting a 20 to 40 amp portable charger and if there is space for a second battery get it.
675 watts solar
mitch5252
NW Tennessee
Not using furnace...roughing it out! Haha.
I have a Honda eu1000i and found out a bit ago battery checked out fine!
No space for second battery.
Might make it to Sheridan WY tomorrow. Hopefully an RV dealer can be found, if necessary.
Sigh.
smkettner wrote: How warm is the thermostat overnight? Put it down closer to 60-65 (or less) (or off)
2008 Fun Finder X-160
2006 Toyota Sienna Limited
Equal-i-zer Hitch
Prodigy Brake Controller
mena661
Ok, missing some info. Is this a recent problem?
Trojan L16 6V's 740 Amp-hours
MEXICOWANDERER
las peƱas, michoacan, mexico
Shucks I don't even trust a battery that's supposed to be brand new. Start there.
Almot
Vancouver BC
Well... You don't need lights this time of year in Alaska. Kill the radio for when not in use - pull the fuse, like Mosey said. You'll lose station presets, no big deal.
Z-Peller
Oceanside BC
As mentioned by a previous post, check your fridge for a humidity switch, and be sure it is turned to "off"....when it is "on" it runs a small 12v heating circuit around the door opening to reduce sweating around the fridge door seal....it will kill your battery in about the time period you are experiencing.....ask me how I know!!
Bill
RJsfishin
Winston Or.
From what the OP said, they have an unusual drainage on the battery,....plain and simple,
Add to that problem,....they have a single stage converter that would have to run 4 hrs a day for even one discharged battery And thats if was working correctly,....which at the voltages given, it may not be !
In that predicament, I'd have an RV elect tech check it out
Rich
'01 31 ft Rexall Vision, Generac 5.5k, 9245 conv, 400 watt inv, 2 12v batts, ammeters, KingDome/sat, Two Oly Cat heaters, and towing a '05 Jeep Liberty, or sometimes towing a Lowe bass boat.
dclark1946
Richardson,TX,USA
mitch5252 wrote: Not using furnace...roughing it out! Haha.
Sigh.
You should be able to go a full day with a healthy Gr 27 battery if you are only operating the basic fridge, water heater, water pump and some lighting. We dry camp for a full week with a single Gr 27 in the Smokies and run the Fantastic vent fan all night long. We charge with a Honda Eu 1000 for about 3-4 hours each morning and the battery charge current drops off from 10A (starting charge) to 3A by that time indicating that it still had plenty of capacity before starting to recharge. Our trailer parasitic current draw with the fridge and water heater on but no lights or other accessories on is on the order of 0.5 A so that is only 12AH per day
If you are going to be dry camping you really need to consider purchasing and learning to use a clamp-on Ammeter to check your parasitic current draw and charging current. Knowing the battery voltage is only half of the information you need to manage your 12V system. Sears carries a nice DC clamp-on that should work well.
Dick
Dick & Karen
Richardson,TX
2007 KZ Spree 240RBS
03 Tahoe/09 F250 V10
mena661
Dick X2, these things are invaluable.
