RV.Net Open Roads Forum: Class A Motorhomes: Why did tire blow
 > Why did tire blow
Raymon
Phoenixville, PA
Posted: 05/23/12 01:37pm Link  |  Print  |  Notify Moderator
Matt_Colie wrote:
Well,
I am not just sure what your question is....
Do you mean why did it "blow"?
It sounds like it did more than "blow". It probably blew, as in lost pressure, some time before you saw it disintegrate. Why it lost pressure is anybody's guess.
Even that disintegration comes in two kinds. Some shred the side wall. This is more common to passcar tires run below load pressure. Others separate the belts/thread. This is more common in heavy tires. and very common in dual set where a tire can be run out of load pressure for an extended period.
Think about that last one...
Most of the tire weight is in those belts.
Do you know what a 22.5 tire weighs?? (hint ~ close to 100#)
Now think about the that belt that is 2/3~3/4 of that tire weight.
On the top side of the tire, it is going twice road speed. That just helps tear it loose. It only hits the fiberglass body at road speed. I was always surprised how little damage that did. I'm not testing cars any more.
Matt
Where in the world did you get your information/facts? Not one thing you stated is accurate. I worked for one of the big 3 tire manufacturers for many years. I think I know a little bit about tires.
Ray
Tombstone Jim
Tombstone Az
Posted: 05/23/12 01:46pm Link  |  Print  |  Notify Moderator
Hmmm 202 in Phonix last week, Temperature 100 + average speed on 202 80mph.
My guess under infaltion, excessive speed, high temps.
2011 Big Country 3450
06 F250 4x4
91 Wrangler
2011 Jeep Liberty
Weathertodd221
FL
Posted: 05/23/12 02:15pm Link  |  Print  |  Notify Moderator
bluwtr49 wrote:
As was said, we'll never know for sure but the most common cause is underinflation. Something a good TPMS would catch.
when one comes out... please let us know. As far as TPMS being good... you seem to be in the minority. Tell us what "qualifies" as good?
Weathertodd221
FL
Posted: 05/23/12 02:37pm Link  |  Print  |  Notify Moderator
steveownby wrote:
The take away from all the destruction is, don't over look your tires. Replace them at 7 years or before especially on the steer axle. Check your inflation PSI every morning before travel. Consider investing in a TPMS. Review the Michelin blowout video and practice what you would do.
Safe travels.
Steve... what is with the 7 yr recommendation? What is this number based on? Why not 3.5yrs or even every year??
Have you ever checked a date code on a tractor trailer??
old guy
Oregon (pronounced Or e gun)
Posted: 05/23/12 03:03pm Link  |  Print  |  Notify Moderator
the tire had a weak spot duh
Tinstar
McKinney, TX
Posted: 05/23/12 03:58pm Link  |  Print  |  Notify Moderator
Some guesses are just better than others.
Never pass up a chance to go somewhere
Blaster Man
Posted: 05/23/12 04:31pm Link  |  Print  |  Notify Moderator
Very few MH tires "blow." My bet would be old age or under inflation, or both.
melvonnar
clearwater florida
Posted: 05/23/12 05:06pm Link  |  Print  |  Notify Moderator
Check with any tire manufactor and tell them you had a blowout whith their tire; you will get all the reasons you could possibly think of.
Matt_Colie
Southeast Michigan
Posted: 05/24/12 12:51pm Link  |  Print  |  Notify Moderator
Raymon wrote:
Matt_Colie wrote:
Well,
Matt
Ray.
Ray,
Could you please be specific about where you disagree.
Where do I get my information? From being an engineering manager of one of the largest independent testing companies in autoland. Did you happen to hear about the Explorer/Firestone issue? I'm the guy that designed the experiments that found the root cause.
So, please if you have a difference point of view and information to share, take advantage of this forum and share it.
By the by, we did a similar set of tests later for a major coach builder that had a tire warranty issue. That is when we photographed (via high speed digital cameras) and weighed and measured and examined lots of different things.
Matt
Matt & Mary Colie
A sailor, his bride and their black dog going to see some dry places that have Geocaches in a coach made the year we married.
 > Why did tire blow
