RV.Net Open Roads Forum: 30 amp and 50 amp electric question
 > 30 amp and 50 amp electric question
psmoore
Illinois
Posted: 05/23/12 12:15pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 30 amp connection. One of the campgrounds I'm looking at staying in is only 50 amp service. I thought I had read somewhere to only use 30amp. Just wondering if I can get an adapter or something and use the 50amp, or do I risk blowing something in my RV? Thanks.
Paul and Susan - 4 kids
2001 Winnebago Brave 35C
Joy
Henderson KY 42420
Posted: 05/23/12 12:19pm Link  |  Quote  |  Print  |  Notify Moderator
Yes - you can get a "pigtail" or "dog Bone" connector to use this hookup.
See ya' down the road!
Don-SCPO USN Ret.Corpsman
Joy-Ret.Off.Mgr.
Maggie-Chihuahua
Chrissie-Chihuahua
Lucy-Jack/Rat
'06 42' Allegro Bus DP
'06 Saturn Vue
LIFE ISN'T ABOUT HOW TO SURVIVE THE STORM BUT HOW TO DANCE IN THE RAIN.
Fire Instructor
Upstate (Albany) NY Area
Posted: 05/23/12 12:21pm Link  |  Quote  |  Print  |  Notify Moderator
All 50a pedistals that I've seen also have a 30a plug-in. You should be fine.
Fire Instructor
2004 Dodge 1500 4dr 4x4
2009 Rockwood 2607
300 Watts of SunTech Solar Panels
Rogue MPT-3024 Controller & Xantrex PW2000 Inverter
"If everyone is thinking alike, then someone isn't thinking!" General George S. Patton
JT19
So. Maryland
Posted: 05/23/12 12:39pm Link  |  Quote  |  Print  |  Notify Moderator
+1 This is how I've seen them all, though I've only been to 7 different camp grounds (just started mid last year)
But, to be safe, I also have a pigtail just in case that stays in the camper that takes a 30a and plugs into a 50a.
I also have a pigtail to plug into a normal 3 prong extension cord incase I just need a little juice and I'm not at a 30a place.
HappyKayakers
Black River Falls WI
Posted: 05/23/12 12:47pm Link  |  Quote  |  Print  |  Notify Moderator
Take an adapter with you. Whether a 50 amp pedestal also has 30 amp and 20 amp outlets depends on how much money the owner had when he was setting up that particular site. I've seen plenty that are missing one outlet or another.
Joe and Dakota, the wacko cat
2006 Dodge 3500 QC CTD SRW Jacobs Exhaust brake
2006 Heartland Bighorn 3600RL, MorRyde suspension, TrailAir pinbox
http://happykayakers.com/blogger/
NORM WADDELL
PENSACOLA FL 32514
Posted: 05/23/12 12:50pm Link  |  Quote  |  Print  |  Notify Moderator
In specific reply to your question
Buy an adapter to allow your 30 Ampere cord
to plug into a 50 Ampere receptacle. These
are available at WalMart or any R V store.
Your input breaker IN the RV will limit
the current to 30 Amperes. Your 30 Ampere
cord will be over protected by a 50 Ampere
breaker, but this is not a problem.
L NORMAN WADDELL
30 FOOT ALLEGRO
SATURN TOAD
WIFE AND 2 DOGS SUGAR BEAR & COCO BEAR
pianotuna
Regina, SK, Canada
Posted: 05/23/12 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
I carry a "break out" box that converts a 50 amp into one thirty amp (with 30 amp breaker) and two 20 amp outlets (each protected by their own 20 breaker).
Using an adapter does leave the pedestal unbalanced but that will not cause you any grief.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
1995brave
San Antonio, TX
Posted: 05/23/12 01:06pm Link  |  Quote  |  Print  |  Notify Moderator
This is not always true. I have been to several RV Parks that only had a 50 amp connector. Had to use a dogbone to plug in my 30 amp RV.
IAMICHABOD
Sunny So Cal
Posted: 05/23/12 01:37pm Link  |  Quote  |  Print  |  Notify Moderator
Some will tell you what to get but most wont show you THIS IS WHAT YOU NEED just a click away
2006 TIOGA 26Q CHEVY 6.0 VORTEC
Recycled El Monte RV Rental
Buying A Rental Class C
smkettner
Posted: 05/23/12 01:40pm Link  |  Quote  |  Print  |  Notify Moderator
Probably need nothing as most 50a sites have 50, 30 & 20a connectors.
Call and ask.
675 watts solar
