2oldman
Wilson Creek WA
cm11599ps wrote: I just ordered enough LED's to fit the entire camper. Are you sure all the bases are the same?
cm11599ps
Long Island
2oldman wrote: cm11599ps wrote: I just ordered enough LED's to fit the entire camper. Are you sure all the bases are the same?
Every thing I've looked at has the same bulbs. I've also seen people use the same fixtures I purchased and they have the same camper as me so I'm assuming I'm good to go. The fixtures I got also have 3 different plugs to fit different sockets.
michael8rc
Here
I replaced all the bulbs in our trailer last summer with the exact same LEDs. Do not have much time on them yet but so far they work as advertized. The light is bright, cool and is just about the same color as the old bulbs.
1998 Dodge Club Cab 4x4
2010 Wildwood 292FKDS
wny_pat
Western NYS
Here is the official recall notice with instructions on how to get free safe replacements: http://www.cpsc.gov/CPSCPUB/PREREL/prhtml11/11716.html
pkunk
Questa, NM
I've been running LEDs for a couple of years and have had several die due to overheating. The first was a 350 Lumin Starlight LED which just quit after all yellow LEDs became brown. The second was a 'Chinese' LED which slowly dimmed (have 2 more doing the same thing) due to browning/heat.
edited 06/06/12 11:20am by an administrator/moderator *
1999 Coachman Mirada 34 ft.V10-F53 chassis
12ft.LR slide-2 gp31 AGM 12V @220AH
cm11599ps
Long Island
I left for camping last Thursday and wouldn't you know it, my LED's arrived that day only I had left already!
Anyway, I tried a few of them. I put on over my sink and 2 in my bathroom. I'd say the two in the bathroom are about the same brightness as the 2 old incandescent bulbs. I haven't actually used the tape to mount the panels onto my fixtures yet. Right now I kind of have them balancing on top of their socket so it's pretty close to the effect I would get if they were attached to the fixture itself.
They are just as bright as the stock bulbs. The stock bulbs give off a yellow tint. These LED's give off a white tint. They also seem to give off almost as much heat as my incandescent bulbs. I found this surprising. I can't comment on the energy savings because I don't have the tools.
mikhen
oley, pa
cm11599ps wrote: I left for camping last Thursday and wouldn't you know it, my LED's arrived that day only I had left already!
I wouldn't say the heat was the same as incandescent, but I was surprised at how much heat there is.
As far as the tape. Don't bother. I even replaced that tape with 3m double sided. I ended up using a very small dab of construction adhesive. Been over a year since I'm using these, no problems yet.
2005 Sunseeker 3100 QBS
camping Pa...win free camping
zztinker
Central California
These are the ones that I got to replace all the lights in our 5th wheel, they are very brite and are warm tone, not white or blue... Very happy, no more sitting in the dark when dry camping..
http://www.ebay.com/itm/10pcs-12V-Dome-Bulb-36-1210SMD-LED-Warm-White-Adapter-BA9S-T10-Festoon-31-44mm-/170721842426?pt=LH_DefaultDomain_0&hash=item27bfd094fa#ht_2195wt_922
2010 Jayco Eagle Super Lite 31.5RLDS Fifth Wheel, 2006 Ford 350 PSD SRW, long Bed, Champion 2000i inverter Generator and a Champion 3500/4000 Gen.
wny_pat
Western NYS
zztinker wrote: These are the ones that I got to replace all the lights in our 5th wheel, they are very brite and are warm tone, not white or blue... Very happy, no more sitting in the dark when dry camping..
http://www.ebay.com/itm/10pcs-12V-Dome-Bulb-36-1210SMD-LED-Warm-White-Adapter-BA9S-T10-Festoon-31-44mm-/170721842426?pt=LH_DefaultDomain_0&hash=item27bfd094fa#ht_2195wt_922 And did you check the recall notice to see if it applied to them?
bondebond
Searcy, AR
wny_pat wrote: zztinker wrote: These are the ones that I got to replace all the lights in our 5th wheel, they are very brite and are warm tone, not white or blue... Very happy, no more sitting in the dark when dry camping..
http://www.ebay.com/itm/10pcs-12V-Dome-Bulb-36-1210SMD-LED-Warm-White-Adapter-BA9S-T10-Festoon-31-44mm-/170721842426?pt=LH_DefaultDomain_0&hash=item27bfd094fa#ht_2195wt_922 And did you check the recall notice to see if it applied to them? What recall notice is that? The one referenced in this thread? If so, that's a completely different bulb/situation, with bulbs that are generally for household lighting. These bulbs above are automotive in nature.
This space left intentionally.
2006 Fleetwood Sequoia and mods...one of the tallest highwall pop-ups on the planet after flipping the axle.
