RV.Net Open Roads Forum: Class A Motorhomes: Valve cores stick !
 > Valve cores stick !
MSHappyCampers
Columbus, MS
Posted: 05/23/12 06:36pm Link  |  Quote  |  Print  |  Notify Moderator
When I bought the MH a couple of months ago I discovered that when I tried to air the tires, the valve cores would frequently stick in when I removed the pressure gauge, letting air pour out. I would put the gauge back on and remove it again, sometimes releasing the core and sometimes not. I replaced the cores in all the tires but am still having the same problem. It doesn't happen as often when I am putting air into the tire with the air chuck, but when it happens it is easier to pop the chuck back on for a second and stop it. Have any of you had this problem and what did you do to correct it?
Joe & Annette
2002 Monaco Windsor 40PBT
Tombstone Jim
Tombstone Az
Posted: 05/23/12 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
Spray em with some silicone spray
2011 Big Country 3450
06 F250 4x4
91 Wrangler
2011 Jeep Liberty
camperkids1025
Bel Air, MD.
Sounds like they had the tires balanced with dynabeads and didn't change the valve cores over to prevent the bead material from entering the stem. Jim
The Camperkids Jim & Lois
3 Grandkids Maria, Christian, Antony (part timers)
1999 Newmar Mountain Aire 37.5ft, Ford V-10, F-53 Chassis, Bilsteins Shocks W/ Bilstein Steering Stablizer, HWH Levelers
crasster
Dallas
Posted: 05/23/12 06:52pm Link  |  Quote  |  Print  |  Notify Moderator
I agree, silicone spray. Also some olive oil could loosen things up.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
rgatijnet1
Posted: 05/23/12 06:53pm Link  |  Quote  |  Print  |  Notify Moderator
If that is the case, they used the WRONG Dynabeads. The correct RV specific Dynabeads are larger in diameter and do not need special valve cores or any changes to a TPMS. They may have used another brand of balancing compound that does require special filtered valve cores.
rolnhome
Casa Grande, Az
Posted: 05/23/12 06:56pm Link  |  Quote  |  Print  |  Notify Moderator
You probably have old air in your tires. As it ages it gets thinner and can flow past the the seal in the valve core stem. You need to put some new thicker air in the ones that are leaking. On second thought I'd do all of them to be safe.
We're in Arizona
rolnhome
Casa Grande, Az
Posted: 05/23/12 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
Seriously make sure you have the higher pressure valve core stem. They make a a high and low pressure stem.
T&A
SE Michigan
Posted: 05/23/12 07:06pm Link  |  Quote  |  Print  |  Notify Moderator
Good question. Same thing happened to me an hour ago. Grabbed my core removal tool and bottle of cores. Tried the gage once more and it was OK again.
Terry
Terry & Amy
2004 Hurricane 30F on P32 Workhorse Chassis
2010 GMC Terrain (Towed)
2010 Ford Escape(Future Towed)
Where are we going.....and why am I in this handbasket?
Tim Nowicki
Alden NY
Posted: 05/23/12 07:08pm Link  |  Quote  |  Print  |  Notify Moderator
If the balance beads are the problem, check your pressure with the stem at the 12:00 o'clock position. Any beads should just fall back in the tire when checking pressure. Works for me. Or the air chuck should blow them back when adding air
2inAlabama
Huntsville, AL
Posted: 05/23/12 07:18pm Link  |  Quote  |  Print  |  Notify Moderator
I would not use silicone as the tiny seal on the core is made of rubber. A trucker told me to use a non-petroleum lubricant, then cap the valve to keep dust out.
Just DH & DW
