RV.Net Open Roads Forum: Tech Issues: generator to run A/C
 > generator to run A/C
steveh27
Grosse Pointe Woods, MI
Posted: 05/24/12 11:40am Link  |  Quote  |  Print  |  Notify Moderator
Lots of past threads on this subject. You may want to search the site.
Here's from a past post of mine:
Definitely check your AC's power draws. They are not all the same.
I had to replace my 11000 btu ac & since Dometic no longer makes it I went with their Hi efficiency 13500 AC. (I think if more people knew about this HE unit they would buy it.) Here's the power draw details using a Honda 2000.
I fired up my new Honda 2000 & plugged the Kill-a-watt meter into it. 126 volts. Then I plugged in my motorhomes 30 amp power cord with the proper adapter. I did not bother turning the breaker off to the converter based on my earlier analysis. The draw was 2.6 amps. Then I turned the AC fan on low. 4.5 amps. Then I turned the AC on and it went to 11+ amps and slowly climbed to 12.5 amps and had no problem running. In my motorhome the AC was nice & cold & the battery was being charged. All lights worked fine. I switched the eco on & had no problem. I switched the AC fan to low let it run for 1/2 hour. The draw then was 11.5 amps. Sweet. This high efficiency AC is worth every penny!
Air temp = 87 (hotter than before)
interior motorhome temp 95+
Gen only = 126.6 volts.
With my MH plugged in & converter left on = 126.2 volts 2.73 amps, 176 watts.
Turning the AC fan on to LO = 125.6 volts, 4.34 amps, 416 watts.
Adding the AC compressor
= 123.8 volts, 11.1 amps, 1210 watts. These slowly went up to 11.52 amps & 1250 watts.
Turned the fan on HI = 123.2 volts, 12.5 amps, 1381 watts. These numbers slowly drifted a bit higher.
Turned the fan back to LO & let it run 15 minutes. Nice & cool inside. 123.2 volts, 12.49 amps, 1400 watts.
My elevation is only 750 feet.
PS I did try the Supco on my original AC & had a RV dealer install it. It seemed to have little impact & the AC unit died later.
big whitey
raleigh,nc
Posted: 05/24/12 01:30pm Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
Hi,
I have a Boliy--supposed to do 3300 watts--but it stalls out at 1100 watts. USELESS.
come on quit beating around the bush tell us how you really feel about the Bolily.
SORRY FOR YOUR TROUBLES
maybz
ontario
Posted: 05/25/12 08:39pm Link  |  Quote  |  Print  |  Notify Moderator
thanks guys for the input. It is a 13 500 btu ac
mena661
Posted: 05/25/12 11:04pm Link  |  Quote  |  Print  |  Notify Moderator
3000W will do this for sure.
Trojan L16 6V's 740 Amp-hours
maybz
ontario
Posted: 05/27/12 05:49pm Link  |  Quote  |  Print  |  Notify Moderator
borrowed a Honda eu 3000 i and it powered up the a/c without a glitch. what a sweet genny, but pretty expensive to use in the boondocks for a couple weekends a year. I might consider a Champion for the price.
bushman512003
wallaceburg,ontario,canada
Posted: 05/30/12 07:37am Link  |  Quote  |  Print  |  Notify Moderator
Buy a big Red aka eu3000is Honda have one never let Me down 2004 bought new still the Battery it came with and starts every time with the turn of the Key....sweet....oh it runs the air no trouble at all...Bush
Keystone 5er Model Cougar 276 RLS ,and all the toys.Enjoying camping,friends, fire. LOL. life is good..John,Jeannette,..From Canada the Queen's Country..Member of IRV2.Com. The Bushman EH!
big whitey
raleigh,nc
Posted: 05/30/12 05:37pm Link  |  Quote  |  Print  |  Notify Moderator
X2
