RV.Net Open Roads Forum: Tow Vehicles: Question for 2011 Dodge 6.7L owners
Search only in Tow Vehicles
 > Question for 2011 Dodge 6.7L owners
mac01
Berryton, Kansas
Posted: 05/23/12 07:52pm Link  |  Quote  |  Print  |  Notify Moderator
Just traded my 2007 Dodge 2500 6.7L for a 2011 3500 DRW 6.7L. Did a test pull tonight for about 40 miles. Pulled into about a 35 - 40 mph head wind. Wow what a difference two tires make in the wind. Over all it handled it quite nicely.
If this question has already been asked sorry in advance, didn't find anything in my search.
The question I have is the engine temp is running about 198 - 206 empty, pulling is was running 204 - 212. Is that about normal that everyone is seeing on the 2011 models? Or have you had the thermostat changed out to 180 and if so are you seeing about 200 degress when pulling? I would be interested in know what the conditions were. For example flat in 100 degree weather or pulling in the mountions.
I had it into the dealer for some other things and to check the engine temp before the test pull. They indicated that is the plan by design because factory is putting a 195 degree thermostat in the 2011 and 205 degree in the 2012.
Sorry got long winded just like the Kansas wind today. :-)
2011 Dodge 3500 6.7L CTD Crew Cab DRW 4X4
2005 Jayco 325BHS
Ranger Smith
Wherever the rig is parked
Posted: 05/23/12 08:08pm Link  |  Quote  |  Print  |  Notify Moderator
That's normal. Mine is around the same
Where I Am Now
Amateur Radio Operator KK9W ARRL VE FT DX2000
Steve and Joy
1999 Winnebago Ultimate Freedom
2011 RAM 1500 Laramie CC 4x4 Hemi
Yogi . . . The Yorkie
Kage . . . The Poodle
Cookie . . . The Chihuahua
Cooper . . . The Aussiedoodle
carringb
Corvallis, OR
Posted: 05/23/12 08:13pm Link  |  Quote  |  Print  |  Notify Moderator
Don't change the thermostat. You will likely see more regen action with a cooler T-stat.
Bryan
2000 Ford E350 DRW Wagon (14-pass all captains chairs)
V10 w/ Banks PowerPack, Diablo Predator, 4.56 LS, ~350,000 miles
New Desert Fox in the works!
45Ricochet
North Idaho
Posted: 05/23/12 08:37pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for that! Some people tell me its all in my mind
Congrats on the new truck. Can't help you with the 6.7 temps but my little old 5.9 runs about the same depending on ambient temperatures, terrain, wind and the skinny pedal.
There is the "Baker Grade" in the S Cali desert that will keep my temperature well into the 215 range for a half hour. I use to be concerned but after many pulls it seems normal.
Good Luck
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
2PM's
Kansas
Posted: 05/23/12 09:03pm Link  |  Quote  |  Print  |  Notify Moderator
Mine is a 2010 6.7L 4X4 2500 bought at Briggs also and your temps are just right. Will climb a bit in the mountains, not to worry.
Ranger Smith
Posted: 05/24/12 04:21am Link  |  Quote  |  Print  |  Notify Moderator
Speaking of . . . I don't think I've ever seen mine go into regen mode in the 13k I have on it. What's up with that ???
eHoefler
ozark mountains
Posted: 05/24/12 06:10am Link  |  Quote  |  Print  |  Notify Moderator
Unless you have a Exhaust Temperature gauge, you will never know when it is in regeneration.
As far as the engine temperature, I have seen 220* on a had pull on steep grades. A/C on, 100*+ temps outside, all is good. These newer trucks have amazing cooling systems!
Don't change the thermostat. You will creating a whole bunch of problems with the emission systems, causing engine codes, poor performance, bad fuel economy, and endless trips to the dealer with codes that won't be covered under warranty when they discover the thermostat was changed to one outside of the specifications on the manufacturer.
2010 Ram 3500, Crew Cab, Long bed, 4 x 4,Dually, Lights & Siren!
2006 40' Landmark Mt. Rushmore
Perrysburg Dodgeboy
Perrysburg, Ohio USA
Posted: 05/24/12 07:57am Link  |  Quote  |  Print  |  Notify Moderator
There is or so I'm been told a change in the sound engine when it goes into regen and you will know when it happens.
Form what Cummins told me the engine will only regen when needed, if you run it a little hard on the highway, towing, or pulling grades even empty the engine will not regen very often, if at all. This came from a QC engineer at Cummins so take it for what it's worth.
As far as the t-stat stay with the 195*
Don
Perrysburg Dodgeboy
2004 Dodge Ram 2500 Quad Cab SLT Cummins HO
2005 Keystone Cougar 304 BHS
Chrysler the only one to pay back 100% of their loans from the Government. *The Old Car Company" still owes 1.6 billion. Is that better Chuckles
ib516
Up here!
Posted: 05/24/12 08:18am Link  |  Quote  |  Print  |  Notify Moderator
An Edge Insight can tell you when a regen is in progress. Note the Edge Insight IS NOT a tuner/power adder, just a monitor.
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
Ranger Smith
Posted: 05/24/12 08:22am Link  |  Quote  |  Print  |  Notify Moderator
I have one and never seen the R in the display
