RV.Net Open Roads Forum: Good or Bad DIY? let me have it.
 > Good or Bad DIY? let me have it.
seraphim
Ohio
Posted: 05/24/12 10:17am Link  |  Quote  |  Print  |  Notify Moderator
I'm no expert on suspensions, but I'm curious how much of a beating those wood shims can and will take; how long until they rot...
I guess I don't see them lasting long.
2012 GMC 3500HD Crew Cab LB 4x4 DRW with Duramax 6.6 diesel
2013 Palomino Maverick 2902. "Panserbjorn
"I am an armored bear..."
bedrocker
lompoc ca
Posted: 05/24/12 10:30am Link  |  Quote  |  Print  |  Notify Moderator
I like the shim ideal I would just make
them out of steel but I'm just a machinist
mkirsch
Rochester, NY
Posted: 05/24/12 10:40am Link  |  Quote  |  Print  |  Notify Moderator
Some days I don't get you guys... I've seen you rip on way higher quality DIY stuff and call it "redneck" "hillbilly" or "dangerous."
I say crude, but effective. The only concern I'd have is with the wedges in the springs, but the worst that can happen there is that they fall out and the truck sags a little...
2002 Chevy 3500 DRW 8.1L/Allison
2000 Palomino B1500
...and the reason why I need a DRW to haul a Palomino:
2004 United 7x14 tandem axle enclosed toy trailer
2011 PJ 8x20 7-ton deckover equipment trailer
firemedic08
North Central PA
Posted: 05/24/12 10:56am Link  |  Quote  |  Print  |  Notify Moderator
Depends on if they've had their Prune juice those days mkirsch. But seriously looks effective to me. Roll On.
Donnie
1994 Chevy 2500 Extended cab
1980 sunline,
JoeChiOhki
Sauvie Island, OR
Posted: 05/24/12 11:53am Link  |  Quote  |  Print  |  Notify Moderator
Me, I would have just bought some add-a-leafs or some real 3/4 ton truck springs... that's like half the total springs in my Dodge's pack....
On the subject of the shims, rot will never be an issue because when the pack compresses and flexes hard that bottom spring a couple times, those shims will start to crack in two and finally fall out.
CB Channel 17 Redneck Express
kerry4951
East Central Pennsylvania
Posted: 05/24/12 12:24pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry but the wood idea just doesnt do it for me. I would rather see you shim somehow using steel. The right idea but the wrong material.
2009 Chevy Silverado 3500 dually D/A, Supersprings, Stable Loads, Bilstein Shocks, Hellwig Sway Bar, Front Timbrens.
2010 Arctic Fox 1140 DB, 220 watts solar, custom 4 in 1 "U" shaped dinette/couch, 59 interior and exterior mods to date and still adding
big whitey
raleigh,nc
Posted: 05/24/12 12:44pm Link  |  Quote  |  Print  |  Notify Moderator
X2
big whitey
raleigh,nc
big whitey
raleigh,nc
Posted: 05/24/12 12:46pm Link  |  Quote  |  Print  |  Notify Moderator
X2
bka0721
Republic of Colorado
Posted: 05/24/12 01:04pm Link  |  Quote  |  Print  |  Notify Moderator
Glad to see you are looking at options and discussing your ideas here in this forum. Lots of good ideas and critiques.
One thing to remember, screws (unless you purchase higher grades) are used for bonding, not support. They are great for providing clamping/pressure when bonding/gluing surfaces together. They have no shear force capabilities.
When attaching items together, use steel nails, joist nails, bolts or gang nailing plates (like joist hangers and hurricane clips).
The best way to demonstrate shear force bonding, take a piece of plywood, screw a deck screw (or drywall screw from what I can see you are using) through this board and take a nail, same length of screw or longer and drive it through the same board. Take a hammer and strike the screw and then the nail on the side of them and watch what happens. Yep, the screw will fracture/break before it bends like the nail bends. This is what is happening between two boards that are attached with screws when the board flexes. I have seen too many DIY'ers build decks with screws where they shouldn't. Be careful and things will last a long time for you and not end up in the middle of the road, behind you.
b
08 F550-4X4-CrewChas-6.4LDiesel-206"WB GVWR17,950lbs
09 Lance 1191
600w Solar~8-6vGC2 928AmpH~Tri-Star45/4 MPPT
Xantrex 2000W
300w Solar~2-6vAGM 240AmpH~Tri-Star45/4 MPPT
Xantrex 1500W
08 BMW R1200GS Adventure
09 7X14 Enclosed Haulmark Trailer
