RV.Net Open Roads Forum: Tech Issues: Heat Pump Vibration
 > Heat Pump Vibration
Duck
Miami Lakes, Fl
Posted: 05/24/12 11:09am Link  |  Quote  |  Print  |  Notify Moderator
On our past trip we needed to run the heat pump in the cool mornings. Every time we turned the a/c to the heat pump setting the unit would start to vibrate. Does put out warm air. It does not do it when using the cooling setting. Dealer checked out the nuts and bolts and ever thing was tight. Has anyone had this problem or have any suggestions.
Don
08-FORD F350 PSD
13 Bighorn 3055RL
trickyvic3
Raymond NH.
Posted: 05/24/12 11:17am Link  |  Quote  |  Print  |  Notify Moderator
Ours seems to vibrate a bit more when on the heat pumps as well. Not really sure of the reason, but ours has done it since new. It's not real bad, but you do notice it more so than when in ac mode.
Chris Bryant
DeLand, Florida, USA
Posted: 05/24/12 11:36am Link  |  Quote  |  Print  |  Notify Moderator
On heat mode, the compressor is pumping directly to the inside coils which makes it louder. On cool mode, the compressor pumps to the outside coils, and the inside coils feed through a capillary expansion tube.
-- Chris Bryant
My RV Service Blog
The RV.net Blog
Duck
Miami Lakes, Fl
Posted: 05/24/12 04:09pm Link  |  Quote  |  Print  |  Notify Moderator
Would this cause the vibration of the cabinets and the plates inside?
Don
dougrainer
Carrolton, Texas
Posted: 05/24/12 07:51pm Link  |  Quote  |  Print  |  Notify Moderator
You need to state Brand and Model of HP and year model. Doug
imgoin4it
Alamogordo, NM USA
Posted: 05/25/12 06:19am Link  |  Quote  |  Print  |  Notify Moderator
For some reason the reversing valve vibrates more when heating. If it is really bad and under warranty you may be able to get it exchanged.
Retired and loving it
Living in the Land of Enchantment
Traveling in 2007 Newmar KSDP
towing a Jeep Liberty
with a Blue Ox tow bar
Duck
Miami Lakes, Fl
Posted: 05/25/12 09:53am Link  |  Quote  |  Print  |  Notify Moderator
It is a Dometic low profile heat pump.
Don
Duck
Miami Lakes, Fl
Posted: 05/25/12 10:01am Link  |  Quote  |  Print  |  Notify Moderator
I was at the dealer this am and their mechanic term the vibration severe. It will rattle the dishes in the cabinet. I found a small motor home with the same unit in it and it did not have near the vibration. Dealer called Dometic and they said the excessive vibration was normal when it is over 60 degrees outside. I guess the battle has started with Dometic.
Don
dougrainer
Carrolton, Texas
Posted: 05/25/12 10:46am Link  |  Quote  |  Print  |  Notify Moderator
Don
1. STATE YEAR MODEL!!!! AND MODEL!!!! THIS is critical to know.
2. You do NOT run a HP when over 60 degrees outside, that increases the HEAD pressure on the compressor as when it is that warm the system cannot remove the heat from the evaporator and the outside condensor (which is cold in HP mode) cannot dissapate the cold because of the ambient heat.
3. NEW 410 freon Dometic model PENGUIN HP's do have a vibration problem. THAT is why year and MODEL is important to this discussion. Doug
