ewarnerusa
Helena, Montana
Hi. Is this type of plug OK with an Atwood water heater to replace the nylon plug? Seems more convenient then keeping a stock of nylon plugs. I don't have a good grasp of the galvanization thing.
http://www.amazon.com/dp/B0000AZAOW/ref=pe_160230_24080570_pe_vfe_dt1
n7bsn
Yes
I wouldn't use it
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
cm
Dillon, CO USA
That style of drain plug is used on the transom of boats. I doubt if that would be a good choice for a water heater.
robatthelake
Vancouver Island
No it is a Poor choice! Use the OEM Plugs ! They are cheap and Work Properly! A New one every year is cheaper than a Cup of Coffee!
Rob & Jean
98 Dutch Star Diesel Pusher ..92 Tracker 4X2
Chuck&Gail
In the Colorado Mountains
I think warranty is void if you use that.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
sharker6
fulltime KY, NC, FL, MA, TN
I use this one
click
2009 30' Fleetwood Wilderness, 2008 F-250 Super Duty FX4 stump puller
Grey Mountain
On the rez somewhere in Indian Country
sharker6 wrote: I use this one
click
I installed one of those on my Atwood, but I'm receiving conflicting information about it. Some have told me it will cause a problem with the threads. But they are sold in RV supply stores (not that that is any guarantee of anything.)
Has anybody had any problems with one like this?
GM
Discovery 39S Tin Teepee
Honda CR-V Toad
Jeep Cherokee Toad
Enrolled member of the Comanche Tribe
English Bride
Bichon Frise bear killers:
Lord Shonefeld von Reginald-Friese IV.
Lady Annabelle von Lichenstein-Friese III.
eHoefler
ozark mountains
The threads are National Pipe threads. Whether you use plastic, brass, or steel, they all will work.
2010 Ram 3500, Crew Cab, Long bed, 4 x 4,Dually, Lights & Siren!
2006 40' Landmark Mt. Rushmore
sharker6
About the only way your going to mess up the threads is over-tightening. After you put Teflon tape on just tighten until you feel too much resistance. Or, fill the heater with water and tighten until it stops dripping.
Chris Bryant
DeLand, Florida, USA
Grey Mountain wrote: sharker6 wrote: I use this one
click
GM
My big problem with those is that you cannot flush the tank- you can drain the water, but the crud stays in.
The plug the OP posted would last until you turned the water heater on.
-- Chris Bryant
My RV Service Blog
The RV.net Blog
