RV.Net Open Roads Forum: Tech Issues: Single cup coffee maker amp draw
 > Single cup coffee maker amp draw
Page of 6
3 tons
CA.
Posted: 05/25/12 08:11pm Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
Hi Kendall,
Since it was a trimetric reading--and the inverter was alarming at 11 volts--150 X 11 volts = 1650 watts.
We might also assume 15% for inverter inefficiency, making the coffee makers actual consumption about 1400w.
3 tons
KendallP
Grants Pass, OR
Posted: 05/25/12 08:13pm Link  |  Quote  |  Print  |  Notify Moderator
Hey Don,
Yeah. I've seen those. That's why I'm a little perplexed here. This thing sounds like some kind of thermonuclear coffee making device.
Cheers,
Kendall
1986 Winnebago Chieftain 22RC
Our Camper (with no payments)
KendallP
Grants Pass, OR
Posted: 05/25/12 08:18pm Link  |  Quote  |  Print  |  Notify Moderator
Of course. Clearly my exhaustion is showing. Too much vacation!
CA Traveler
The Western States
Posted: 05/25/12 09:47pm Link  |  Quote  |  Print  |  Notify Moderator
crankshop1000 wrote:
Are you sure you haven't confused watts with amps? I'm calling BS on a 150 amp draw coffee maker. You would need a major solenoid and battery cable sized wires to pull 150 amps for a full minute.
I initially had the same question. But it's a 120V AC coffee maker running on an inverter. So 150A DC is possible. And he said it was a Trimetic reading so that includes all other non coffee pot battery loads.
2009 Holiday Rambler 42 Scepter with ISL 400 Cummins
2004 Honda CR-V
Bob
mena661
Posted: 05/25/12 10:58pm Link  |  Quote  |  Print  |  Notify Moderator
KendallP wrote:
Hey Don,
Might as well throw some popcorn in that thing while he's at it.
Trojan L16 6V's 740 Amp-hours
Gau 8
United States
Posted: 05/25/12 11:14pm Link  |  Quote  |  Print  |  Notify Moderator
Reading is fundamental.
lfeather
Titusville, FL
Posted: 05/26/12 06:49am Link  |  Quote  |  Print  |  Notify Moderator
We use an extension cord through the kitchen window that's plugged into the 20 AMP socket outside. Now my volt meter stays on 120 (no drop or fluctuations) when making coffee in the morning. We have a string permenantly attached inside that the wife drops out during our normal hookup routine. This allows us connect the cord for retrieving it inside and then we to drop the cord back out and lock the window when not in use.
Larry, Debbie, Tiki and Tomi
USAF Retired
2003 36' Country Coach Allure #30856
2008 Tacoma Towed
SMI Air Force One toad brake
Texas Two Steppers
Beaumont, TX
Posted: 05/26/12 08:06am Link  |  Quote  |  Print  |  Notify Moderator
Here's the skinny on the single cup coffee maker. It is a Hamilton Beach A84. It is rated at 1300w @120v. This morning I closely monitored the Trimetric during the brewing. My wife uses a different setting from me, which uses a constant amp draw rather than pulsating and I tested her's. My resting amperage on the Trimetric was -2.5 amps. when the coffee maker was turned on it went to -130/-141 amps and stayed there for 2 minutes. (Yesterday it was showing 152 amps. so something else mush have been on that I didn't notice). I left the lbco at 11.1v and the inverter didn't shut down but the batteries weren't as low as yesterday. The batteries recovered to 12.5v fairly quickly. They were at 12.6 from overnight useage. I thought the amp draw in the literature was the max.
2013 Duramax 3500 dually 4x4
2013 Excel Winslow 31RSE
TST tire monitor
Magnum MS 2012 inverter/charger
3-135w solar panels
Tristar controller
Trimetric monitor
4-6v Trojan t105 batteries
B & W companion 3000 hitch
mena661
Posted: 05/26/12 08:17am Link  |  Quote  |  Print  |  Notify Moderator
Ok, then just set the inverter to alarm at a lower voltage when you're doing the coffee your way.
CA Traveler
The Western States
Posted: 05/26/12 08:54am Link  |  Quote  |  Print  |  Notify Moderator
I added a second cord to my rig with 2 inside plugs that could be used for ceramic heaters or coffee pot. The cord terminates in the back and is plugged into the engine block heater outlet.
So if we are on 20/30A and and extra pedestal plug is available we're all set up inside. With 50A or gen we just have 2 extra inside plugs.
Page of 6
