RV.Net Open Roads Forum: Tech Issues: Single cup coffee maker amp draw
 > Single cup coffee maker amp draw
Page of 6
3 tons
CA.
Posted: 05/25/12 06:15pm Link  |  Quote  |  Print  |  Notify Moderator
Sticking to the inverter matter I Just checked the factory low voltage cut-out setting on the ProSine 2.0. The values are adjustable, and range from 10.0v to 16.0v. Two previous inverters I've owned had fixed only settings of 10.5v. For your given scenario, I think you'd do well to simply lower the cut-out point to 10.5 and see what happens.
3 tons
crankshop1000
se michigan
Posted: 05/25/12 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
Are you sure you haven't confused watts with amps? I'm calling BS on a 150 amp draw coffee maker. You would need a major solenoid and battery cable sized wires to pull 150 amps for a full minute.
mena661
Posted: 05/25/12 06:53pm Link  |  Quote  |  Print  |  Notify Moderator
You guys aren't reading. The OP got the 150 amps from his Trimetric. It's not BS.
Trojan L16 6V's 740 Amp-hours
KendallP
Grants Pass, OR
Posted: 05/25/12 07:17pm Link  |  Quote  |  Print  |  Notify Moderator
150 * 12.5 = 1875W
That's a little high, but not totally unreasonable.
Cheers,
Kendall
1986 Winnebago Chieftain 22RC
Our Camper (with no payments)
pianotuna
Regina, SK, Canada
Posted: 05/25/12 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
Hi Kendall,
Since it was a trimetric reading--and the inverter was alarming at 11 volts--150 X 11 volts = 1650 watts.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
MrWizard
Traveling
Posted: 05/25/12 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
at low voltage of 11v * 150 = 1650 input to the inverter
takes a lot of power to heat a cup of water real fast
edit I see pt beat me too it
Connected thru Verizon with HotSopt WiFi using a Samsung Galaxy Nexus
I BOUGHTthis phone
2oldman
Winchester WA
Posted: 05/25/12 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
Yes. What would you say it is?
* This post was edited 05/25/12 07:51pm by 2oldman *
KendallP
Grants Pass, OR
Posted: 05/25/12 07:31pm Link  |  Quote  |  Print  |  Notify Moderator
Roger that
Still... I'd like to know the make and model of this thing. I've not seen one like this.
And FWIW... I also give high regard to the Melitta cone jobs. I have a single in the RV. The only downside is you have to pour very slowly and carefully to get a good brew... just like a drip maker would do. Or you can stir like you would with a press. Otherwise your not going to get a good, complete brew.
To me the press is pretty easy to clean. At least as easy as a percolator... yet LOTS of RVers use those things.
And for those that tout solar to run their coffee makers... what happens when it's cloudy? Days like that are made for EXTRA coffee!
2oldman
Winchester WA
Posted: 05/25/12 07:52pm Link  |  Quote  |  Print  |  Notify Moderator
It would have to be cloudy for two days straight to affect me.
pianotuna
Regina, SK, Canada
Posted: 05/25/12 08:05pm Link  |  Quote  |  Print  |  Notify Moderator
Hi KendallP,
I found a lovely 4 cupper from Cuisart that draws 400 watts and only uses about 7 amp hours. As a bonus it has a metal insulated wall pot.
Page of 6
