RV.Net Open Roads Forum: Travel Trailers: Exterior Shower parts needed
 > Exterior Shower parts needed
K G G
NW Houston
Posted: 05/25/12 09:45am Link  |  Quote  |  Print  |  Notify Moderator
Hello,
I replaced my (Phoenix?) exterior shower yesterday - the handheld and hose only.
Managed to break the connector by the cold/warm handles when I tightened the hose too much (it kept leaking).
Can I get this 90degree connector somewhere or will I have to buy the whole exterior shower kit?
2009 Palomino Puma 28BHS, 2011 Chevy Tahoe, Pro-Series 49902 WD-hitch w/sway control.
Travelling with 6 girls - you figure the distribution :-)
SilnJohn
Denver
Posted: 05/25/12 10:20am Link  |  Quote  |  Print  |  Notify Moderator
You could try this guy http://www.rvadenver.com/
He's a local shop down the street from my office, anytime I've needed a small misc part he's gotten it for me.
2012 Toyota Tundra Crew max 5.7 Limited
2005 F150 Lariat 4x 5.4L, 3.73 (80K mi 4sale cheap needs.......work)
2003 Nissan Pathfinder
2012 Shadow Cruiser 260BHS
K G G
NW Houston
Posted: 05/25/12 10:35am Link  |  Quote  |  Print  |  Notify Moderator
TY. I send them an email with picture.
ecoast
NW NJ's Highlands
Posted: 05/25/12 01:15pm Link  |  Quote  |  Print  |  Notify Moderator
you can try to repair with jb weld
07 5.9 CTD & 2000 Northstar Laredo TC towing 87 Samurai ORV on dual axle trailer
K G G
NW Houston
Posted: 05/25/12 01:54pm Link  |  Quote  |  Print  |  Notify Moderator
Not familiar... What is jb weld?
kearlms
Rexburg, ID
Posted: 05/25/12 02:03pm Link  |  Quote  |  Print  |  Notify Moderator
JB Weld is a two part glue. Hardens enough to be drilled, sanded, and painted. Very food for a lot of jobs. Works on wood, metal, most plastics. Their Link.
johnnstace
Minneapolis, MN
Posted: 05/31/12 04:59pm Link  |  Quote  |  Print  |  Notify Moderator
You are probably going to have to get a whole new unit. The polypropylene that those are made of is very difficult to repair. When you get a new one and put the hose on again make sure you have a new gasket in the joint. If you have an old one or the wrong one it will leak for sure no matter how much you tighten. Same goes for the nozzle end.
K G G
NW Houston
Posted: 06/19/12 08:19am Link  |  Quote  |  Print  |  Notify Moderator
I was able to disassemble the whole unit, then cut off the angular plastic part that was broken so that only the upright stem remained.
To that I affixed the straight shower hose, also cut off, with a small hose clamp and voila... all fixed for less than a dollar in cost. :-)
HappyTrails2U2
Tennessee is home but being held hostage in GA.
Posted: 06/19/12 09:11am Link  |  Quote  |  Print  |  Notify Moderator
K G G wrote:
Hello,
Sounds like you're speaking of the connection at the hose to the trailer that broke not at the shower head.
Speaking of leaks on shower hoses did you know that handheld shower heads are designed to leak? I was trying to buy one that didn't leak because I thought mine was defective but I read it's against the law for US manufactures to make them where they don't leak due to safety concerns over the hot water which sounds like a bunch of boloney to me but evidently it's true.
2010 Rockwood Signature Ultra Lite 8315BSS
2003 Chevy Silverado 1/2 Ton Extended Cab
K G G
NW Houston
Posted: 06/19/12 09:51am Link  |  Quote  |  Print  |  Notify Moderator
The part that was broken is the stem that comes out of the handle/mixer assembly, to which one screws the normal shower head hose.
I had broken that by overtightening.
Interesting point on the showerhead.
