chrism28
billings
anyone know how to get rust stains off white alluminum sideing?
stubblejumper
Saskatchewan
CLR available in most hardware or building centres
1999 Winnebego Chieftain
Wayne & Leila and Teddi (the Kid in the brown fuzzy pyjamas)
We are not 2 people that own a dog, we are 2 people that are owned by a dog ..
chrism28
billings
Do ya have to soak it
Turbo Diesel Dude
Green Mountain, NC
I had some on my interior wall paper and wiped it down with some peroxide. Came rtight off. JMHO
charles weidman
Adventure
Michigan
I used Goop the white hand cleaner in the round tub to get rust off of Gel Coat siding. I would try it on the aluminum. You could also check out Iron Out it can be used on houses that have been sprayed by sprinklers. Read the label.
2005 F250 V10, 4x4, CC,
Tow Command
Our Condo on Wheels
2005 Sunnybrook 33FKS
Hensley Arrow-Love it!
Places we slept in our RV, have also visited WA,NV,CA,HI,MN without rv
stubblejumper
Saskatchewan
Re CLR
Just spray it on and sponge it off. Takes rust off vinyl siding under out door taps in minutes. Good for bathtub scum and calcium deposit, grease etc
Doughboy12
Minnesota
I founds that the ZEP brand of the same stuff works better.
chrism28
billings
How about aluminum sideing
BigDogF250
Ramona, CA
Mr. Clean Magic Eraser and some simple green.
The biggest problem is that the white is a covering (usually paint) over the aluminum so you can't attack it with anything too harsh. If you use the magic eraser you will need to follow up with wax, it tends to take some of the shine off.
Don't take life too seriously, it's not permanent.
06 Weekend Warrior FSC3200 pulled by 05 Ford F250 PSD 4x4
07 Yamaha YZF450 White/Silver, 94 Husqvarna WXC610
2008 Polaris RZR 800, 2011 Honda CBR1000RR and one Goffin Cockatoo
jdweikel
Palm Beach Gardens, Florida
We use Star Brite Rust stain remover on our boat and they state it will also work on metal. You can find it at just about any marine supply store.
2007 GMC CC/SB Duramax/Allison 2500HD 4X4 SLT
2007 Crossroads Paradise Point PF30CK
5th Airborne sidewinder combo
16K Reese
Timbrens
Prodigy Brake Controller
2003 Parker 2520 pilot house
